Pics of 285/70/17 tires
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
I know this is a thread for those metric 33's on 17" wheels... but I thought I'd throw my 16s setup in the mix...
- Old Man Emu (Heavy Load) Suspension Kit
- Total Chaos Fabrication UCA's (to regain caster)
- Black Rhino "Arsenal" Wheels in Sand on Black (16x8 and -10et)
- Goodyear Wrangler Duratrac tires (285/75R16)
The front crash bars had to be cut for clearance, but I've torqued and twisted it a lot and have absolutely no rubbing at all, on or off road. My MPG hit was about -3 on the highway and -5 in town. I don't feel the need to regear or anything, as the turbo and 10-speed never seem to miss on finding the powerband I need.
Awesome setup. Your Ranger looking good.
Wesmertz
Wesley
Utah
2021 Ford Ranger SXT FX4 Crew Cab
Grocery Management
+35 Black Rhino Stadiums with Toyo aT3s, Fox 2.0s
That’s the setup I want! Except for I want to use factory wheel. I was thinking a 1” spacer should work. I’m want to run basically a 32”x10.8” tire on my stock 18” wheel. No crash bar cutting. Fox 2.0 level.
SPEEDBUILT
Zak
SacTown
2020 Ford Ranger Lariat FX4
Strength Coach
If you use a true 32” than you may want to run 25mm, or 30mm spacer to get that look. My wheel has 20mm difference than stock.
I average 17-18 mpg around town...19 maybe 20 highway...
Sure, but how many lumens per gallon - or is it too high to measure? ?
OC4095
2019 Ford Ranger XL
Factory Automation Engineer, Auto School Grad, Car Audio Tech
285/70/17 BF KM3 muds on stock wheels
1.5” spacers
2.5” RC plates
Front crash bars rubbed at full lock, mostly drivable though. Had to cut them.
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
Eibach 2.0 stage 1 adjustable coilovers up front set at 3.5 inches
Eibach 2.0 stage 1 rear shocks
Fabtech upper control arms
Fabtech rear 1.5 inch lift blocks
What lift and suspension you are using?
OC4095
2019 Ford Ranger XL
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Thanks for the pics I have Fox coil over in the front, with superlift suspension 3.5 inch and Eibach in the rear. I'm going to thesame as you have in the near future in the front setup. I think it is better without the spacer. Did you do a diff drop?
