New Product - Morimoto XB LED Replacement Headlights
Status
Not open for further replies.
Jrel209
Wa
2020 Ranger XLT crew cab
3 questions
1) any option to change DRL amber?
2) do they have any cringy light-up animation? If so, can they be turned off?
3) i have an xlt how hard is it to install? Theres mention of different harness from xlt to lariats
Synyster06Gates
Austin
Liberty Hill, TX
Looks like the website has lost it's dang mind...
As much as i want these, and I dislike the AlphaRex - I'm really having second thoughts. These Morimotos have much cleaner lines and, to me, blend to the truck better.
Making your customers wait this long, and tossing on a premium price tag, that's not how business is done.
Need some beam pattern analysis, bc these sucker DO have THREE BI-LED PROJECTORS! That would be some serious light output.
These are from one of the FB pages... To say I'm disappointed is an understatement. I'm happy I went with the $600 Alpharex lights.
For reference, here's my setup with drop in replaceable LEDs.
CoachJ
Rhett
2021 Ford Ranger Tremor
Teacher/Coach
I've had "both" setups (had the 3 LED setup in my '13 F150) and can tell you that the Morimoto WAY outperformed the Alpharex. I put LED bulbs in my Pros and they were decent but had issues with reliability so I went back to halogen and did not lose much output. The Morimotos in my previous truck were insane; I never even felt like I needed the high beams.
Now how they'd compare to the 3-LED Alpharex I can't say, but I'm most likely about to put my Alpharex headlights up for sale. The high beams on these are atrocious.
I think the comparison in these pics make the Alphas look superior, but it's always difficult to tell in different settings with different cameras, ambient lighting, etc...
Edited to add: the "reliability issues" I speak of have absolutely nothing to do with the Alpharex lights. Something with my truck and the LED bulbs didn't jive.
Every headlight product drops the ball by not making amber a color option for the DRL portion.
I inquired with Alpharex if I could get amber DRL’s instead of white. They answered me back, not at this time. If enough potential US customers inquired as well they might just make some that way seeing the competition is doing that now.
For me, I like the Mori’s but not at that price. I could go through 2 sets of Alpha’s for that… Hmmm wonder if I can open them up and put amber in there anyways. Done it to other headlight assembly’s before. Just need to be patient doing it and keep the work area very clean and dust free.
Synyster06Gates
Austin
Liberty Hill, TX
It's a switchback. It could be done, just a programming thing.
Ranger8729
Ashley
South Carolina
1987 Ranger & 2019 Ranger
Okay, some information to add. After asking Morimoto's customer service about the installation/wiring and how the DRLs would work, I have a better understanding. They provided a link to a youtube video that has some great info - link is HERE.
The headlamps themselves are plug and play. You can swap the assembly and the lamps and turn signals will work as they should. This includes the chase effect of the turn signals, which is optional also. The DRL, however, is independent of the entire assembly - it has it's own harness that uses a fuse tap to get ignition power, and once powered, will light up the DRL outline. The DRL will not function without the harness in place.
This causes issues for the XL/XLT crowd(who arguably will be the biggest base looking for upgrades) whose DRL is the low beam headlamp bulb. The upgraded assembly does not take into account the truck's DRL signal, and will illuminate all the low beam LEDs. This, apparently, will not flicker, but will still run unless you turn off the DRL in the truck's dash settings or Forscan.
The light pattern itself is really great however. I have attached two screenshots from the above referenced video of the low beams. The Morimoto clearly blow away the stock halogens (interestingly the stock halogen high beams are very good, while the Lariat is weirdly shaped and fuzzy) but only provide a small boost over the Lariat pattern. The actual usable lumen output is greater than the Lariat, and the spread is also better, but I can't see a Lariat owner buying these for any reason other than looks. The XL/XLT crowd, this will get you some nice lighting for sure!
I am currently still debating a purchase. I do not like the "V" look of the AlphaRex, and feel the Morimoto fit the lines of the Ranger better with the DRL. However, having the DRL be independent seems kinda lame. I'm not sure if the setting to turn off the XL/XLT DRL in the dash is permanent or resets after key start?? Overall, they are a great looking set of lights that I feel complement the truck very, very well, but for only a 25% increase in output over Lariat lights, that price is hard to swallow. The warranty and quality of Morimoto does have its' merit, however.
RBTremor
Rod
Detroit, MI
1966 Mustang Convertible, 2019 Mustang Conv. 2.3L
Superdannyboy
Looks like taco headlights.
Still better than my stock halogen with LEDs.
I would get some alpharex with amber DRL's, but only the halogen ones and put LEDs in there, otherwise I'd rather put money towards performance.
I'll trade someone all of my "Sport" package wheels for their lariat headlights.
Ranger85
St. Louis
Not familiar with them, they reliable? Their price is almost half which is intriguing. Damn ford for not making led lights standard heh
Honestly, I am not sure. I’ve heard good things about the GTR line in general but that was related to their drop in bulbs. The price is great and I do like the way they look. Already on back order so I’ll probably wait to see some real customer reviews.
Ranger85
St. Louis
These are reflector lights NOT projectors like the Morimotos or the Alpharex. Just have none replaceable LED bulbs.
I saw that too… not sure they will be as good as projector housings which may explain the price.
yamahaSHO
Greenwood, AR
www.jaztuning.com
Anyone have an issue with delayed turn-on from one side? I seem to have this with low and high beam, like it's processing or flipping a relay later. Removing power does not show it to be an issue with the truck.
Status
