New Product - Morimoto XB LED Replacement Headlights
Status
Not open for further replies.
Ranger85
St. Louis
These are reflector lights NOT projectors like the Morimotos or the Alpharex. Just have none replaceable LED bulbs.
I saw that too… not sure they will be as good as projector housings which may explain the price.
yamahaSHO
Greenwood, AR
www.jaztuning.com
22 Ranger, 23 Maverick, 04 S2000, 07 Sky RL
ECU Calibration - USAF Retired
Anyone have an issue with delayed turn-on from one side? I seem to have this with low and high beam, like it's processing or flipping a relay later. Removing power does not show it to be an issue with the truck.
Figarou
No delay with mine. Both turns on at the same time.
yamahaSHO
Greenwood, AR
www.jaztuning.com
That's good to hear. It's clearly in the control/relay system in the light itself as removing power is instant. I sent a message to Morimoto via FB and they read it and didn't respond, so I sent an email. I really hope this isn't a hassle as I've purchased many Morimoto products over the years.
Figarou
Hopefully they can send you another one. This is the 1st time I've heard of this problem.
1pt21gw
West Coast
'20 IS XLT SC / '22 OW BBB 2Dr
Ye' Ole Traveler
Intrigued as I have my eyes on a set.
Waiting on that 3rd brake light to be in stock first. Much easier to replace.
yamahaSHO
Greenwood, AR
www.jaztuning.com
Morimoto is telling me it's normal. I replied stating I've already asked this question to other owners and it's apparently only normal for me. I hope I don't cross off another company on this situation.
It’s probably a feature. Lighting both simultaneously is probably a high power draw to the system so a slight delay lighting one then the other reduces this type of draw more than you would think.
Onemig
Paulo
MD
2022 Ford Ranger Tremor
YamahaSHO,
I just received my XB headlights and did a test run first before installing the headlights. Mine does the same thing, driver side headlight has a slight delay when turning on the low beam and flashing the high beam. I am actually fine with this but decided not to install the lights and contacted Morimoto for a different issue.
When I reconnected the factory halogen headlights, I decided to look at it very closely. As it turns out, it also does the same delayed driver side light up. It is harder to notice though since the halogen filament has to “warm up”, masking the delay, were-as with the LEDs, the delay is pronounced because of the instant on nature of the light, making it obvious. Could it be that some Rangers come from the factory with this delay?
TeaWrecks
Vincent
Canada
2021 Ranger Tremor XLT
May I ask what issue are you having with them?
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
My Morimoto XB come on almost simultaneously, there is a very, very slight delay with the driver side. I can't even see it in the video, but in slow-mo the all 3 passenger lights come on, before any on the driver side do.
Onemig
Paulo
MD
The headlights were not working properly
My message to them:
“Hi,
I bought a set of CB headlights for my 2022 Ford Ranger. Upon receiving the package, inspected and tested the headlight. 2 things I noticed that prevented me from installing the light and decided to contact Morimoto first.
1. The DRL harness is missing
2. The driver side headlight has an issue. When using either the hazard lights or the left turn signal, the inner most LED projector lights up and the middle LED projector flickers. This happens together with the turn signal.”
They said the issue is because the lights only work properly while the engine is on. Funny they mentioned this since I stated at the beginning of my email that my package did not come with the DRL harness.
I decided to have them ship me the DRL harness, and test the headlights again once the harness arrived.
The headlights are now installed together with the DRL harness and it is working as intended, key point being that it works properly while the engine is running and DRL harness attached. W/o the engine running, I was still having some minor hiccups, although not as much vs. when the DRL harness was missing.
TeaWrecks
Vincent
Canada
I have the same behavior on mine but since I bought them from someone else I can not go through their support.
My truck went into limp mode twice and both times it was left off with the hazards on for about 5-10 minutes. Saw another member on here mention that the lights trying to go through the startup sequence and shutting off in the middle of it is probably generating error codes. Dealer never asked or said anything about the lights but they did replace one of the control modules.
I'm somewhat tempted to just strip them of their controller and just do it myself. If they ever give me a hard time that'll be the way forward.
I might also try to use Forscan to change the DRL to be the turn signals to see if they can't be amber DRLs.
JACKSMYDOG
Jay
Ontario
I had some similar issues with mine, when I first installed them but marked it up to;
1) Installing the RTR grille & lights at the same time. They are connected in series to the headlight harness.
2) Being in Canada, my lights are all automatic. The only control the headlight switch offers, is to turn parking or headlights on when it's daytime. My DRL come on when ever the truck is running. My headlights, tail lights and running lights come on automatically at dusk, whether my switch is in the off, on or automatic position. The only way to turn them off is to put the truck in park, then apply the parking brake. Or at least this was all true wth factory Lariat lights and no RTR grille lights.
The video above shows testing with the truck running in park. DRL come on when my lights are set to off. When I turn to running lights, the DRL dim and the RTR grille lights come on with the marker and tail lights. That is how everything should function. The next day when I was out on the road, I had my lights off, so it only should have been DRL, but in a reflection I noticed the RTR lights were on as well. After some playing I found that in park, they work as prescribed, but in gear, the XB DRL dim to running lights, and my RTR lights come on.
I disconnected the DRL harness, and had the flickering/extra headlight issues, so I re-connected it and was just going to accept it for what it was. Then while making Forscan changes to my tire size, I noticed DRL settings and one of them was "running lights on with DRL", which was set to on (weird because my running lights didn't come on with my original Lariat DRL). I turned that off, and now my DRL stay at full brightness during the day, but now my RTR lights come on as soon as I start my truck too.
Also my headlights are now not automatic when I'm in the off position. At night I can now have just DRL and RTR lights on, with headlights, running lights and tail lights all controlled by the switch.
Status
