Mouse Attack
GearHd6
Connecticut
Ram 2500
Peppermint Oil needs to become your best friend. Spray down the engine compartment once a week for several months. Get some outdoor traps (I suggest glue traps/be careful of poisons especially if you have pets). Open up your air box and check cabin filter box.....they like to nest inside those.
Do you have a special peppermint oil potion?
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
Order 100% pure peppermint oil on Amazon. Look up on Google the mix ratio to water for rodents. I believe it was 1>10. I have used it in my RV engine bay and it has kept them away 100%. I also use glue traps outside to catch any on my lot. (I get a plastic tub, cut a small hole in it, put glue trap inside, bait it, put on lid. This way cats and dogs don't have access to it but mice and rats get stuck on the pad. If alive when you find them, dunk in bucket of water).
EJH
Ed
Subarus, 2021 Ranger
Grandpa Gus from Amazon.
I spray it around the garage edges. When I leave the Ranger (or other vehicle) parked for an extended period in the garage, I'll spray the engine compartment and around the tires. My neighbor's Jeep was a victim of a rat attach a few months ago.
banerjek
Kyle
Had the exact same thing happen. Except they also made a nest by the cabin filter filling it with all kinds of stuff -- including small rocks. Fortunately, no real damage and it was just a big cleanup job.
I've sprayed liberally with peppermint oil. Don't know if it helped, but they haven't come back
ambit
Philly
2021 Ranger SCAB 4x4
I added some metal mesh to my engine air intake, cabin air intake at the firewall and cabin filter. No mice this weekend
a33maxi
New England
2021 Ford Ranger XLT 4x4
Cleaned out a nest on my cabin filter a few weeks ago, and laid down some poison bait. Found this guy yesterday. May need to add some wire mesh like you guys have done.
Reactions: R_B
JDowns
Coeur D'Alene
2021 Ranger XLT Tremor
I’d have to second peppermint oil. The RZR sits in the barn half the year and has never been touched. If I could spray down the entire barn I would. They make a mess of the insulation. Found one this year stuck in the shop vac, he got in but couldn’t get out. Can’t really fault them for finding shelter, but chewed wiring is where I draw the line.
I like the tub with a hole in it to keep the traps away from the desirable critters. Good idea.
BrassSlinger
Rich
Western North Carolina
2022 Velocity Blue Tremor Lariat,2017 Honda Civic
Technician
Works for me as well. No issues after using the oil mixed with water
Jmckinley
Southern Ohio
Ford C Max, 2019 Ranger XLT SuperCab, Kawasaki VX 300, Mazda Miata, Damon Motorhome
Retired Engineer
Stinky cab for a few weeks now. Today I found nest #1 on the cabin filter. Clorox wipes, straw and some shiny things they collected. Plenty of mouse poop in the filter. No dead bodies.
Nest #2 in the Jack storage area under rear drivers side seat in Scab. It’s sealed from the cab but there are four large holes leading into hollow body panels going everywhere.
Now, the big question- How to get rid of the smell?
R_B
Southern Nevada
2019 Ford Ranger XLT 4WD
I was just refreshing my little canisters under my hood yesterday when I saw this thread.
I use old CBD balm canisters from Lazarus Naturals. Maybe a Skoal can would work too.
I drill 2 holes on the bottom and about 9 holes on the top. Run a zip tie through the bottom 2 holes. Stuff with cotton and saturate with Peppermint Oil from Amazon.
Screw the lid on and zip tie them next to your battery, fuse box and the other side of the engine bay.
Knock on wood, no problems yet though I see mice traps in the neighborhood.
There is also a cat ? that's pooping on the side of my house.
Hopefully it's dead mice! ? ? ?
GearHd6
Connecticut
Ram 2500
Do you need the screening under the dash if you already have the screen on the firewall under the windshield wipers?
halligan1201
Byron, IL
2020 Ranger
Emergency Management
I use the Grandpa Gus packets too. They work wonders. I have them in the firewood pile too.
Langwilliams
Langley
Lorain, Ohio
. But so does a stray cat! Just feed it once in a while, and no more mice.
My daughter had a few stray cats around her property. It had a large barn with some high dollar quads in it, an RV an her attached garage. The cats all left. I think a neighbor was feeding them better an they never came back! Her explorer ended up getting the hvac system destroyed by mice.
