- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,617
- Reaction score
- 8,808
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
There is another avenue to reset that date - Forscan (Battery Type), note what is currently set (selected) change it to something else and then set it back.I used to see those higher voltages with the old battery and my SOC set to 95% mostly in the cold mornings (40-50 degrees) or colder. When I first put in the new battery and saw the voltage swings I'd sometimes see the voltage briefly go to 14.5 but since setting it to 100% is seems to have calmed things down a bit. It's only been a couple of weeks.
BTW, I tried to reset the battery in both Forscan and using method in the manual but Forscan keeps telling me the battery is almost 1500 days old. Anyone else seen that?
peterb
I do not remember off hand if there was a (pre-programmed) selection in Forscan to upgrade up to the Lariat battery (800 CCA) from (720 or 760 CCA).
I do remember there was not a EXACT selection and you have the option to bump the size in either direction.
But the point is changing this selection, changes the Time Since Installed - Date
Another possibility - This makes sense - Forscan - Run a NEW PROFILE and see if it changes, this will force a new module scan and may update that PID.
