Hard Folding Tonneau Covers
Typow
Tyler
Delaware
2019 Ranger XLT Super Crew
I am looking into a cover that can be easily removed, the Lomax looks like the best choice. Although now I am realizing any cover would block the use of a Yakima ladder rack system, Bummer. Upon further research, truck covers USA has a sliding system called the American Rack, that incorporates the ladder system. Not to mention how Bad Grass it looks!
Hack_Actual
Justin
Oklahoma
2019 Ford Ranger Lariat FX4
It’s as expensive as hell though!
Ramesh
Ramesh
Los Altos, CA
2019 Ford Ranger Lariat FX4, Magnetic
KingsPoint75
SC
2019 Lariat
I installed the Agricover Lomax Professional with the diamond pattern aluminum exterior. The extra reinforcement bar in each panel makes it more sturdy in my opinion. It hasn't leaked sitting in my driveway during a rain storm. Haven't driven it in a rain. The tailgate closed easily with the cover closed. I've had Pace roll ups (in a box that takes up too much bed), as well as the plasticized canvas and bow flop in the breeze models. This one is more satisfying. The first thing my wife asked was about the very shiny aluminum reflecting into the cab. I haven't noticed it yet. It lies below the rear window and is barely noticeable in the rear view mirror. Invisible in the side mirrors. If it does bother me, I'll eventually take it off, mask it and paint a flag on it. I figure that as is, it's going to keep the bed cooler than the black Ford bed spray would.
Install with one person is possible. The spring clamps would be a real help, as would being young enough to lay down in the bed. An extra person would be ideal. The directions are fairly clear though the pictures are poorly lit and there are not sufficient views. Placement of the clamps is fiddly, as the lips under the rails are multi-layer and the shims are awkward to set. The clamps probably shouldn't be pushed all the way to the upper end of the lip on the inside. They may clamp a bit easier if they are lower on the rail.
There are two filler blocks which go on the outboard ends of the front cross-bed railing (front wall of the bed). There is a gasket which covers the rail between them. [....}gggggggggg[...] The gasket may gap a bit [...]here gggg and here [...] when you cut it. I haven't noticed any leaks over a drop or two. If it is worse in a storm when driving, I'll put silicone sealant at those two locations, let it dry and it will be fine.
There are three big panels and a very short panel that serves to cover the rear of the join when they are all folded
____________ ___ ____________ ____________ so you get (PU rear)
____________
____________ |
____________ | when it's folded. (PU rear)
Only possible downside I've seen is there isn't a second set of latches in the middle.
1 2 3
____________ ___ ____________ ____________ (tail gate)
Latch here / none /\ here \ latch here
I didn't see any flex on the road so it may not be an issue.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
____________
____________ |
1 2 3
Need some pics of your diamond cover. I went with the black and really like it. I also see no need for more latches.
kieefer
keith
Just ordered a Gator FX from Gator/RealTruck. If you chat with them you can get a discount.
coblueberryranger
Jesse
Tulsa, OK
2019 Ford Ranger XLT
IT Consultant
I got the gator efx and I love it! chatted with them and got the discount as well
BDoc
Bryan
WA
2019 Ranger Lariat FX4 SCrew
This is the Agricover Professional Aluminum on the 5' bed and the Weathertech flaps front and back.
That diamond-plate looks great with the chrome on your truck :like:. I got the regular, black Lomax and love it; I agree with you on those shims though...awkward as hell. I didn't even think about lowering the clamps a bit to see if it made install easier. I may have to make that adjustment since it looks like one of my rails isn't sitting quite right anyway - have to hold it up a bit to secure the cover after only a couple of weeks on the truck.
kieefer
keith
Got my Gator FX today and installed it myself in a couple of hours.
IngotSTX
Barry
Indiana
2019 Ranger STX FX4 Supercab
Beware of sharp edges on you Lomax covers. I just did this by sliding mine across the tailgate:
29RJi8TrnoHSkFJrVCmE2m_jzi9b-ETGV5H3WMjuUQXO4WP4QP-rKrgZJQ--8QbxyFKnbghO0cWIwIMpDkU=w723-h963-no.jpg
BDoc
Bryan
WA
Well, damn! Thanks for the heads up. I'll have to make sure I'm careful in the future.
BZAMORA13
Brandon
Hawthorne, CA
Do the Gator EFX covers fold up near the rear window to allow room for bikes or larger items in the truck or is there always a fold that stays down? If it doesnt fold up and out of the way is it easy to remove and put back on? If not are there alternatives that do this? Thanks!!!!
