Engine cover (revisited)
ranger7424
Allen
Arizona
2021 Ford Ranger XLT Sport 4x4
Hmmm.....do you think that Ford Engineers deleted it due to engine overheating? Or do you think the Ford bean counters dropped it to save money? I added it back because I believe the latter.
Our 2.3 isn't air cooled...the cover does little to nothing to increase or decrease under hood temp...it's made of light weight foam...but it's worth it's weight in GOLD! ?
OFC Ranger
Jack
ZR2
AND WHY DO YOU NEED AN ENGINE COVER??
If you hold the CTRL key on your keyboard and use your mouse wheel you can adjust the size of text on your screen instead of subjecting everyone to one of the oldest cardinal sins on the internet since the internet came to be.
OregonRangerTremor
Craig
2021 Ranger Tremor/2022 Bronco/2006 ChargerDaytona
Retired LEO/Dog Trainer
Well damn, another site for me to pour money into LOL
It is actually quite reasonably priced. Watch for % off sales around various holidays. They will likely have a sale Memorial weekend. It cost me more to have it painted than the cover itself.
ranger7424
Allen
Arizona
I'm not complaining LOL, I see plenty there for my truck I would like to get.
scarchild35
St. Louis
2000 Ford Ranger
Sales Engineer
I have the JCR cover on my Ranger, with a slight modification I did, to clear my BOV. Pics are in my build thread below.
I had the OEM foam one, when it was less than $100 shipped, but when it soared to $250+, I said screw it and looked for different options :)
Wow, that looks freaking killer. How hard was it to install? I want one for my Ranger and I clicked the link and they only come in black? Not a total deal breaker but I'd like a blue one to match my velocity blue paint (well, not match exactly but you know what I mean...)I know, I'm geeky like that. Thanks in advance.
Mirage775
Huntsville, Alabama
Water Meter Tech I
It was simple to install! It comes with all the hardware and brackets needed. It came with some extra pieces, that weren't even needed...? Zero instructions included... :( You have to download them on their site, but I just had my laptop beside me, while I installed it.
If you have aftermarket parts, like I do, you're going to have to modify it, like I did :)
It would be easy to sand and paint a different color. Whatever they used to spray it black, chipped off easily, although I was cutting it and heat was involved, LOL!
Also, ignore all these comments on here about extra heat in the engine compartment, LOL! I have aluminum aFe charge pipes and they've never made the engine bay any hotter than when it was stock... People just like to complain about everything..
NotBudule
XLT
I was thinking about getting one until I found out the Engine Cover is responsible for the carbon buildup on the valves , and also causes erratic shifts and early transmission failure, that coupled with it also being responsible for the drive line vibration and the number one suspect in the "fuel in oil "saga made it a "No" for me ...they do look good though...
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
You soak it in rat poison and it solves that other issue.
Max Crafter
Max
Canada
Ranger
Why doesn’t the Mustang cover remind you of the speedo? That cover is just a bad idea to me. You have to remove it to change the oil and when you do you have to be very careful not to lose those Ace hardware pieces that are not locked in like oem. Then you have to cut a corner off it which looks a little amateur. Then you have extra bolt heads poking up above the cover as well as the recessed factory bolt holes with no bolts. Sorry, just garbage to my eyes….but not to some as you say.
Because I think I covered that in my statement already. I don't need to explain myself further.
I look at his attempt as prototype #1. Most of your concerns can be rectified with extra work and effort.
I just cant get past the extra heat either cover will retain and any long term effects that may bring to wire, hose and engine components, just to look pretty. Its like layering your clothing for the winter, but keeping that attire all year long.
Covering up the ugly hasn't outweighed that concern as of yet, if its even a concern. Haven't seen anyone do a temp comparison for data.
Wablackwell22
Andy
Columbia, SC
23 Ranger
Paralegal
FYI TSB 23-2011
2 questions about that TSB: 1. Can I try to get this through my dealer using this TSB even if I'm not seeing the check engine light caused by the water in spark plug well? 2. The TSB is only currently for the 19-22, will/does it still apply for my 23MY?
21Blackout
Brian
Ny
21 Ranger
Warranty Administrator for FMC
PM your vin to me and I will see
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
A simple fix to all your concerns is to add a TG damper - problrms soved.
If there were a concern about 'extra heat' Ford, and other auto manufacturers, would not have designed the engines with covers in the first place. The engine covers aren't aftermarket add-ons. Many Rangers, Mustangs and Broncos had them from the factory before 'supply chain issues'.
