Did my own oil change with an unexpected find
Deathrider
s
Illinois
2019 Ranger FX4
Just did my own oil change after taking to the dealer for oil changes the past 3 times, the process was easier than expected but the oil pan bolt was already stripped and the oil filter cover clips were broke, never again will I bring it to the dealer, I also removed 7 quarts of oil!
Im not sure how much of that is fuel but i doubt it was a full quart, I switched to Amsoil with 6.1 quarts, I will change at 5k and see how many quarts I pull out then.
Deerhunder
Adam
2021 Ranger
Ops
No one, and I mean no one, will ever treat your vehicle they way you will. When you perform your own maintenance, you know it’s done right. The dealerships can keep those free oil changes. Now days, dealerships aren’t making big money on vehicle sales. People will shop around and internet pricing can do away with most haggling. They are making money on service. Service plans is how they get you in, then the next thing you know, they will try to sell you all kinds of extras or “recommend” tasks at $100/hr.
Just did my own oil change after taking to the dealer for oil changes the past 3 times, the process was easier than expected but the oil pan nut was already stripped and the oil filter cover clips were broke, never again will I bring it to the dealer, I also removed 7 quarts of oil!
HenryMac
Mech. Engineer - Retired
Yep... dealerships put the guy with the least experience on the grease rack...
The oil drain is a bolt, that has a seal on it, that runs into a tapped hole in pan. Are those internally taped holes ok?
Deathrider
Deathrider
s
Illinois
2019 Ranger FX4
The oil drain is a bolt. Are the threads in the tapped hole in pan ok?
Yes it's a bolt, I edited my post, everything looks good, no leaks ect.
HenryMac
HenryMac
Deathrider
Deathrider
s
Illinois
2019 Ranger FX4
7 quarts could be fuel contamination. Did it smell like gas?
Yes, it always has but I never really saw a rise on my dip stick, it was always at the top hole, now the level is at the end of the hash mark
I don't know if its normal but the dealer always charged me for 7 full quarts also the label they put on my windshield said 5w20, I confronted them about the windshield label and they said they put 5w30 but their machine only prints 5w20 all the time.
Deathrider
Deathrider
s
Illinois
2019 Ranger FX4
So you bought a new drain bolt?
No, I put the same one back on I did not want to wait, I didn't trust what the dealer was putting in there, im ordering a new one to have ready for the next oil change.
Joeiconic
I’ve only had dealer oil changes for at least the past 35 years. Not one issue. Anything can happen, but if the dealer screws it up it’s their problem, if I screw it up it’s mine. Plus I don’t have to crawl under my truck every 5k miles :wink:
Deathrider
Deathrider
s
Illinois
2019 Ranger FX4
Im ok going under, it's easy since I put on larger tires and the Fox 2.0 leveling kit.
I also like to use Amsoil on all my vehicles.
myothercarizahearse
Cleveland, Ohio
Unretired
I’ve only had dealer oil changes for at least the past 35 years. Not one issue that i noticed. Anything can happen, but if the dealer screws it up it’s my problem, if I screw it up it’s mine.
fixed that for you.. not like they would ever admit fault
Canadian Ranger
New Brunswick Canada
Did I misread your original post? Fuel in your oil!?
Keep us posted on your thoughts on the Amsoil. Smoother running, better fuel economy etc.
