Did Ford change my oil
CB750F
Qc
Human
I'm stupid paranoid, I check my oil when I pick the truck up at the dealer. I did the blended for the first 3/4 changes, now, only synth.
Mine always looked kinda dark(blended), always wondered if they changed it but after a few 1000 km, it's dirty, not dark. Check when u pick it up, make sure they actually put oil & did not forget....
JesseS
Jesse
NorCal (Roseville)
Thanks for all the suggestions. I will check the filter and for other evidence. I was thinking it should be pretty clean still. If I can’t tell for sure, I’ll just do a change myself. Haven’t done one on this vehicle so I should learn that anyway.
I mark my oil filter on the end with a sharpie, that way I know if the filter was changed.
chasbo
Charlie
Washington state
2020 Ranger Lariat
IT
Now that’s a good idea for next time!
And I do love me some rum, the good stuff though, not the stuff you have to add sugary soda to in order to make it palatable...
not to derail the thread but im not much of a drinker anymore. but down in the bayou they take smokey sugar cane and satsuma oranges and let it age in oak bourbon barrels. its unique. i would not say its the best rum ever. but worth trying.
so did they change the oil?
svogt302
Tom
Parsippany, NJ 07054
I use Rotella full syn. Very light in color. At 3000 miles, it definitely is not dark brown in color. I change at 10k or less, and then it is dark brown. Smells old, but no fuel smell. After all, it's a 2019 :eek:)
A look at the oil filter drain would show if it was done. Or just look at the shiny filter.
Doesn't Rotella contain alit of zinc? Not supposed to be great for catalytic converters I understand.
dtech
colorado
if you don't have an oil burner shouldn't be an issue, I used it for yrs in my Saab 9-5 but it called for 5w-40 , whereas Ranger is 5w-30 recommended.
svogt302
Tom
OK... I just wouldn't use diesel specific oil on a gas vehicle with cats....
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Diesel have many more exhaust clogging emissions devices than we have now as well. I am sure oil spec changed for that. Rotella is typically cutting edge for diesel requirements. But do your own homework before your cat clogs up.
dtech
colorado
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
i used Rotella in all my old Cummins diesels. They loved it. Like a happy sailor and rum...
I did the same in my Freightliner.
svogt302
Tom
link to an article regards motor oil and additives, near the bottom is a chart that shows content, zinc in found in diesel rotella isn't a whole lot higher than some gas engine oils. Zinc is an effective anti-wear additive.
https://www.motortrend.com/how-to/1...-bottle-of-oil-really-does-make-a-difference/
ZDDP (essentially zinc/phosphorus} is the issue & Rotella is much higher.
Helpful for my 427 Galaxie but not for my Ecoboost.....
Use whatever floats your boat.
