- First Name
- Dave
- Joined
- Jul 25, 2019
- Threads
- 340
- Messages
- 26,757
- Reaction score
- 135,118
- Location
- Back Home In AZ!
- Vehicle(s)
- 2023 Ford Ranger Tremor
- Occupation
- Retired...Full Time Slacker
The wire doesn't have to be tucked all the way inside the A pillar. I tucked mine just inside the plastic (unseen) at the edge and it held up like that for 4 years. Besides the force of the air bag would blow right past a loosely tucked wire with ease.I think the point is, and I never thought about it until this post
In the event of crash - will the wire (slow down) or (Block) the Side Curtain Airbag from Deploying
If routed in front of the airbag and you have the wire secured tightly - (Yes) would be the answer
Right from Blackboxmycar:
https://www.blackboxmycar.com/pages/dash-cams-and-airbagsIs it safe to run my dash cam wirings over my airbags?
While airbags may be sensitive, running wires behind them is completely safe. The airbags will continue to function normally upon dash cam installation, and the cables have no impact on their safety performance. The only thing to make sure of is that your wires are tucked in behind your airbags, so if the airbags do get deployed, your wire doesn't come out with it.
In fact, for installations done at BlackboxMyCar, our professional installers usually remove the A-pillar trim, exposing the airbag and other wiring behind the A-pillar.
Most vehicles already have some wiring going up the A-pillar, such as wires to the dome lights, vanity mirror lights, and so on, so it is safe to run your dash cam's wire along these other wires. If you want to make sure that the wires do not interfere with the airbags, you can secure the wire with cable ties or electrical tape as well.
