- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,694
- Reaction score
- 8,998
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
I think you may have a spread pin on the OBD Port, vibration while driving losing connection.I've tried 2 obd2 cables from Amazon and Best Buy and it still has this problem. It's not the 5 minute shutoff, while driving it cycles to parking mode.
You have this same setup? Does your truck have auto start/stop?
While parked and camera running, slightly and slowly jiggle the connector to see if you can duplicate the same issue as driving.
I do not have a dash cam but tried to find some information on how the OBD (Connector) provides power and the ability to determine when ignition is shut off in addition on how the plug reads when ASS is active.
From what I can tell the Thinkware Cable is an 8-Pin connector (Universal)
But I believe that for the Ranger it utilizes these pins:
Pin 4 = Chassis Ground
Pin 16 = Power (Always Hot)
Pin 6 = HS1 Can Bus +
Pin 14 = HS1 Can Bus -
The Can Bus = The Communication for Ignition Status & Start / Stop Status.
This would also is the Input for the dash cam to enter driving or parking mode. If I am correct.
So, if a lose connection on Pin 6 or 14, could be triggering the Drive / Park mode switching if indeed that it is using those pins as a source.
I would have to see one apart to know if those 2 pins are actually a wired input for the adaptor.
Note: Some OBD Dash cam adaptors on use 3 Pins -as active
Power Pin 16 and Ground (Via Pins 4 & 5)
Pin 4 = Chassis Ground (Scan Tool Power - Ground)
Pin 5 = Signal Ground, this is the ground for Scan Tool (Communication)
The rocker switch on the adaptor, allows either constant power or kill power when the engine is not running. I am thinking it uses the charging system (higher voltage) to trigger it on but could be wrong.
Edit:
I did some further digging and yes pins 6 & 14 are the trigger for Drive & Parking modes, it is only looking at Can Bus activity, so when you close the door and the modules time out. The dash cam enters parking mode, then uses the dash cam settings for Low Battery Voltage monitoring for the dash cam to not power up (In a low battery voltage situation)
When you open the door, Can Bus activity is registered and the dash cam enters driving mode, if engine is not started the Can Bus activity will stop and the dash cam will re-enter parking mode after the module goes back to sleep.
In ASS (activation) mode there is still CAN Bus activity on pins 6 & 14. so, the dash cam should continue recording.
