Anybody planning to lower their 2019 Ranger?
Hi Doc,
Thanks! Okay...you have a high mounted panhard rod and this defines your new rear roll center. The old hoskitch was roughly the center of the diff case. So it is significantly highter. And will changing handling. Not sure about straight line, but as the vehicle squats on accel, there will be a rear axle shift to the left not sure to what extent this shift will be but can be a contributing factor to wheel hop. If shocks and tire pressures are ineffective, might be time to invest in some traction bars to help out the cause. I hope that the improve weight transfer will do the trick with shock adjustment...
Doc
Doc
Live oak fla
Hi Doc,
Yes, I adjusted the rears to low compression and high rebound...perfect..did a burnout on one of our country roads..itcame out straight as an arrow and no wheel hop !
Thank you for your help! Also I’m adding a fiberglass tonneau cover, it’s pretty heavy I’ll also address the front shocks ...
Regards
Doc
P.S....It doesn’t turn the corner like a loaf of bread anymore:like:
Rinn69
N. Central Iowa
Retired USAF MSgt
I just about had a heart attack.....went to Bell Tech's website to check.....they actually have the Ranger listed , but only have shim kits. Maybe this will come around by late summer/early fall ? :please::thumbsup:
MyLittleRanger19
Andrew
Princeton, TX
2019 Ranger STX
Electrical Engineer
Saaaaaaaame
I might have made some interesting sounds too
MyLittleRanger19
Andrew
Princeton, TX
2019 Ranger STX
Electrical Engineer
can confirm.
email response as of 10AM yesterday:
"hello,
thank you for contacting Belltech. Unfortunately, the ranger kits have been pushed back until right around New Year's."
i replied asking for any more information and specs on possible kits.
MyLittleRanger19
Andrew
Princeton, TX
2019 Ranger STX
Electrical Engineer
latest reply from belltech:
"unfortunately i do not have any information on the kit. we wont know the exact specs of the kit until the kit is released. i believe that the new ranger kit will be right around a 2"/4" or 3"/5"."
Doc
Doc
Live oak fla
Sooner or Later...
Rinn69
N. Central Iowa
Retired USAF MSgt
FGMazzola
Frank
Houston, Texas
2017 Mustang GT Premium, 1932 Ford 3 window coupe
Sooner or Later...
Good morning; it's been a few months since I've made any post. Crazy times we are living in and just trying to remember what day of the week it is presents a challenge!
Anyway, I finally spoke to my contact at BellTech (Customer Care and Technical Support Manager) again on the 17th and this was the response:
Hello Frank,
Well I have some good news and some not so great news. We finally found a truck to do our final test fits on and we completed it this week.
However, this means we can start production on the kit which will take several months. Usually we would be able to complete this in about 2-3 months but with everything going on in the world we have not been getting material as fast. I am hoping by the end of the year.
I can tell you that the kit will come with an adjustable strut that will lower the front down 3", a upper control arm to maintain alignment and suspension geometry, and an adjustable rear flip kit that will do 4-6" of drop.
So, maybe a bit more precise information, but still a few months away.
Kevin Franklin
Tinmender1963
Louisville KY
Honda FT500. Honda 700SC. 2019 Ford Ranger Sport. 2014 Ford Focus ST. 2017 Ford Escape Titanium. 1994 Ford Ranger Splash. 1986 Ford Mustang GT Splash
Damn good question. A lot of different things
Hello Frank,
Thank you for the update. Much appreciated!
