2.3L EcoBoost SP-594 Spark Plug Change Write-Up (60k Miles)
Trash Panda
Trash Panda
Cody
Very nice snap-on Torque wrench… friggin amazing write up, my wife read it with me, now she thinks this is something she can do with how much detail you put in..
Maybe ill just sit back and supervise with a fine beverage while she does the work?
That would be a great team building exercise. ? Add some music to the mix. ?
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Bryan, skinned knuckles and cussing while you have a cold one. Will only happen once. ?
OGMix376
Bryan
She’s a tough one..
She actually got her first taste of that doing her own oil change on the little Nissan.?
carnut122
Tim
GA
1953 F100, 2008 Saturn Sky, 2019 Ford Ranger
Rumor has it NGK makes some Motorcraft plugs, I have a feeling these are since it’s stamped “Japan”.
NGK advises against anti-seize.
I’ll know in 60,000 miles if I should have. ?
Thanks for the write up. I enjoyed it and will refer to it in a few years. I always put anti-seize on spark plugs and aluminum threads in particular-it may not be needed, but I sleep better.
NickH
Nick
San Tan, AZ
2020 Ford Ranger
Thanks for the write-up! Now, I could just be an idiot here (very plausible) but I just wanted to state for posterity that the Coil Connector doesn't just "wiggle off" it's still a pinch tab even after sliding the lock off with your thumb. I was putting WAAAY too much force into removal earlier today trying to get my plugs out, thankfully a quick YouTube video gave me what I was looking for.
Aside from that one critique, excellent write-up, and thank you again!
P.S. You'd think that in Arizona my #2/#3 plugs wouldn't be rusted like an '87 Chevy at 60k miles but here we are!
Another member with Water in the wells - well documented on here, you got lucky they came out without issues or hassle.
They are known to corrode so badly they separate and leave the threaded base behind, some have had to replace the head but with some patience and an easyout they can be removed.
fusseli
EE
Did mine today. It was pretty easy but #4 definitely needs some patience to get the coil boot back on without wedging it into the open space around the plug and not actually line up with and sink onto the plug.
~73k miles, FP tune since ~21k miles, plugs did not look bad but they are worn. The new Ford Performance M-12405-20T (Denso ITV24) plugs have a "channel" in the electrode that the Motorcraft plugs did not.
https://www.levittownfordparts.com/...o&utm_medium=email&utm_campaign=map&y_b_lid=2
21SCAB
Ken
Louisville, KY
2021 SCAB Ranger XLT
I did mine at 53K miles. Of the probably 20 vehicles I changed spark plugs on, these were among the least bad. Definitely approaching time to swap them out and for under $50, it was well worth it. I didn't have any rust issues like others have noted but did get the OEM foam engine cover in order to prevent any future issues. My truck came from a generally dry area and appears fairly garage kept so that might have a bunch to do with it.
For any folks out there that haven't changed yours out: I recommend it. Of all the cars I've worked on, these are by far the easiest especially compared to a 428 CJ or 4.0L Ranger.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
fusseli
EE
Racket
Here and There
Transient
Motorpsychology
Prescott, WI
Vagabond
...Or an '86 Aerostar.
TJC
I agree. The 4.0L in the Ranger is indeed a challenge! Pretty tight space to work in! My 2020 was far easier.
Av8or1
2022 Explorer Timberline, 2023 Ford Mach-E GT
Great write-up thanks! FYI Ford recommends replacing the boot at the same time as the spark plug. It's very easy to do and I would agree. With nearly 150hp per Liter... that's tough on the ignition system so I wouldn't neglect it.
