What leaf springs are you currently running?
yungbman
Brandon
2019 Ford Ranger Lariat FX4
I know this has been asked quite a bit but I thought id ask again while scraping through the forums
Just found out my driver side leaf spring snapped and im looking to finally upgrade and what to see what everybody is currently running, im know of the EMUs & Icon kits and also the tremor swap but wasn't sure if there were any other better options?
At the moment im currently not expecting any heavy loads but I have purchased a contractors cap that I plan to camp out of in the future so I guess safe to assume id eventually have the typical overland equipment build in the back to give you an idea of weight id be carrying
Superspirit
earth
22 ranger
I am running the ROW springs, but don't think they are an option any longer.
TJMarchand
Trevor
Medford, MA
2019 Ranger XLT / 1984 Monte Carlo SS
I am looking at the Icon springs currently, but I'm curious if you know as to why the global springs aren't an option. I believe the part # is jb3c-5560-te for anyone looking. One seller has the new in England and does not ship to the United States.
Superspirit
earth
22 ranger
I just figured with the shipping costs now that it would make them out of reach. There was a thread about it on here but I don't have any links anymore.
SonoranDesertranger
Stan
Tucson, az
Ford ranger
Emt
The global wildtrak springs. They're pretty good.
Colo_Ranger
Icon are fine for stock weight. Once you start adding weight, they can't keep up. I have the OME 2.2" and they are good. Several of my Ranger friends have switched to the Dobinsons and really like them. @AndyMedic had the OME and switched to Dobinsons and is much happier with the Dobs.
I plan to switch to the Dobs.
CammeronJ
Cammeron
Hillsboro, OR
Ford Ranger XLT 2020
Engineering Technician
I'm running ICON Multi Rate Leaf Pack with the "Add a leaf". Don't run them, I bought them prior to seeing all the reviews about them squeaking. All they do is squeak non stop. It doesn't matter that they're torqued to spec it doesn't matter if you torque them lifted or not. Doesn't matter if you grease the hell out of them. They will squeak with every slightly bump or wobble of the vehicle. Parking lots sound like I'm driving an old rusted beater around.
Aside from that they work perfectly...
Someone on here tried to warn me but I'd already received them and others said they had them and that they were fine.
When I have a bit more money that I don't want to spend on other bits of kit I'll swap them.
If you want functional and quiet go with Old Man Emu leafs instead.
TJMarchand
Trevor
Medford, MA
This is super helpful to me, I was leaning Icon but multiple reviews mention the squeak. Old Man Emu recommends some weight in the bed I'm usually unloaded. I guess Dobinson might be the best upgrade spring for me.
MountainMan
Ryan
British Columbia
Currently running the OME EL120R springs, i ended up about 2" over stock height in the rear without any weight in the bed and had to shim the pinion down to get rid of driveline shudder. Another thing you have to plan for when you lift the rear is axle wrap, fortunately with the constant load I carry I don't have issues there, but if you're going to be running empty its something else to consider and potentially fix.
If you don't plan on raising the front end id go with something that retains stock height, Deaver's are a good option for that, a little pricey but you won't have to gamble on ICON leafs.
fusseli
EE
I've had my ICON springs over a year and they are dead quiet / don't squeak. And I am very happy with the upgrade over stock.
My camper's leaf springs do squeak, and a spritz of lithium grease once or twice a year is all those need.
2021Ranger
Barry
NJ
2021 Ranger
Here’s your icons that don’t squeek. I removed them and added F150 spring plastic spacers to stop the squeak. Oh and Icon says they dont have any complaints about that.
TJMarchand
Trevor
Medford, MA
That's really bad for a premium/upgrade part. Did the F150 spacer stop it?
TJMarchand
Trevor
Medford, MA
Yes it did. Not that they care but I’ll never buy another Icon part again.
I'm glad the spacer stopped it, but I'd feel very upset after spending that money. I have their upper control arms but your experience leads me to skip the leafs. Thank you.
PapaBill
Bill
Savannah, GA
2019 Ford Ranger Crew 4x4
USMC Retired; Mech.Engineer
MountainMan, When you say the pinion are you speaking about the ring and pinion final drive gears in the rear or the intermediate support bearing in the drive shaft? I am a little confused.
Thanks,
Bill
