Upsized Oil Filter Thread
t4thfavor
Chance
So from my snazzy research I've determined that its an FL-910 oil filter. In prior vehicles I have swapped that for an FL-400s (or Mobil1 equivalent) which allows you to put a little less than half a quart more oil in.
With this being a weirdly placed filter, I was wondering if there is enough room between the existing filter, and whatever else is behind it?
Anyone change their oil yet? If it's 5.7quarts, you can safely put in 6 quarts with the upsized filter.
Also anyone seen a relocation kit for this engine yet? I'd like to not have to squeeze into the wheel well to change the oil (I live on several miles of dirt road).
-Chance
PandaMotorworks
St. Louis
2019 Ranger 2017 Titan 2008 Ford Focus 2014 Ford Fiesta ST
FL400 will fit and we will be releasing our oil change kit very soon with one and Amsoil so you guys can get a great price on some of the best oil out there and earn reward points on our site!
HoosierT
Tyler
Fishers, IN
-Chance
I thought the capacity was 6.2 qts?
t4thfavor
Chance
Confirmed it’s 6.2. Changed my oil today, piece of cake.
Yeah, it was 5.7 to 6.0 quarts in the Focus 2.0T, put it right on full, now that could be that .2 was left over from the last change, but IDK.
Also looking for the Mobil 1 Filter, so far it looks like M1-209 or M1-211, but not sure which I will end up using.
Andy
Andy
The bypass pressure rating is not the same on the FL-910(14.5 psi) as it is on the FL-400(20 psi).
FL-400 Specifications:
Thread Inside Diameter (in.): 3/4"-16
Outside Diameter Top (in.): 2.98"
Outside Diameter Bottom (in.): 2.98"
Length (in.): 4.14"
Spin-On Filter: Yes
Bypass Valve: YES
Color: White
Burst Pressure (PSI): 250 psi
Pressure Relief Valve: YES
PSI Relief: 20 PSI
Micron Rating: 80%@20um
Height (in.): 4.14"
Seal Outside Diameter (in.): 2.75"
Seal Inside Diameter (in.): 2.40"
Anti-drainback Valve: YES
FL-910S Specifcations:
Thread Inside Diameter (in.):3/4"-16
Outside Diameter Top (in.):3.15"
Outside Diameter Bottom (in.):3.15"
Length (in.): 3.36"
Spin-On Filter:Yes
Bypass Valve:YES
Color:White
Burst Pressure (PSI): 250 PSI
Pressure Relief Valve:YES
PSI Relief:14.5 PSI
Micron Rating:50%@35um
Height (in.):3.36"
Anti-drainback Valve:YES
passgas55
State of LA
2007 chevy w/t
Just by going figuring the volume to ounces of the filter with out taking into consideration the filter media space.
Fl 400 is 16 oz while the FL 910s is 14.6. All based on outside dia. About 1.4 oz difference. I don't know if the filter media is
the same size or any other internal components. Need to cut open one of each new to see.
passgas55
State of LA
2007 chevy w/t
Thinking more about it , what I am going to do is measure how much oil to fill a FL 400 and do the same for the FL 910S. I use the FL 910S on my lawn equipment. I just have to get a FL 400.
t4thfavor
Chance
FL400s fits, it was a PITA to get the original off, I think they had a gorilla tighten them off the line.
I initially filled with 6.5Q, then added about another .25Q after running the engine for about 2 minutes and letting it sit for 15 minutes. The oil line was about 1/4" below the full mark until the extra .25 went in.
So about 6.75q brings you close to the full mark. I think 7 would go in, but it's too new to try that kind of stuff yet.
4800 miles on the ODO.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
Just did my first change, so I’ll share some thoughts, no particular order.
  • Wix 1516 (it’s the cross for the FL-400s) fits quite comfortably. There are zero issues with fitment, it doesn’t rub the shield or anything.
  • I pulled the wheel off since it was my first time. I would agree with what most are saying: it’s not required but it does make it nicer to work. Do it with your tire rotations.
  • 6.5 qts got me to the full mark.
  • The filter drain trough wasn’t where I thought it was! There’s another trough forward, roughly on the wheel centerline. The one we want for the filter is behind the sway bar. I got an arm full of oil.
  • 15mm wrench for skid plate and drain bolt.
  • My factory filter wasn’t overly tight. I didn’t have the right filter wrench on hand so a pair of channel locks got it off no problem.
  • If you’re the I-don’t-need-no-stinkin-funnel type, stand down and buy a funnel. The oil fill hole is quite a bit smaller than other Fords lately.
HotPepperLariat
Rod
Appomattox Virginia
VW Touareg
Sorry for the cross post on the Ranger 6G forum but I didn't get any responses. So I just picked up oil and filter for my 2024 Lariat 4X2 with the 2.3 liter which uses the same oil filter as the 5G models. I figured this group has much more Ranger maintenance experience. Anyway, I was somewhat appalled at the small size of the filter. It is only slightly larger than he one on my lawn tractor's 725cc engine. Has anyone fit a larger capacity filter on their 2.3? Maybe I have nothing to worry about and assume the Ford engineers know what they are doing.
RangerBill
I have heard of some using the Motorcraft FL400s filter which is longer. I use the recommended Motorcraft FL910s filter. There should be no need to go bigger.
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
If you're having transmission issues, I feel bad for you son. We got 99 problems, but the oil filter ain't one.
Since I do 5k oil changes, going bigger is probably just a waste.
