The 2" Stubby Jr Antenna is Great
Pat McGrath
Pat
Philadelphia PA
2019 Ranger 4X4 XLT Supercrew
I purchased and installed the 2" Stubby Jr antenna and didn't lose an iota of reception. The antenna is hardly visible on the truck because it only sits about an inch above the fin.
Osage
Wade
Austin, TX
2019 Ranger Lariat FX4
Agreed. I also installed it and couldn't be any happier. All the better when purchased through @PandaMotorworks.
Manny
Manny
2019 Ford Ranger XLT
I bought 3 different antenna options from Cravenspeed, I will try all three tomorrow and see which one looks best. They have a great return policy so I felt ok ordering all three to test. I will post pictures of all three.
Desert_5G
Eric
Arizona
Tacoma
after not paying too much attention to the OEM antennae. turned out I only have ~1" of clearance between that and the top of my garage door. If I was to add any lift to it and reverse it. Goodby antenna. One of these is a must for garage parked lifted Rangers.
Arron
Arron
Seattle, WA
2019 Ranger SuperCab Lariat FX4 Sport Magnetic
Software developer
Just tested out the Stubby and the Stubby Jr. compared to the Original in the diagnostics mode. There is a signal strength test in there and I used that to get the following results.
  • Original - 62
  • Stubby - 43
  • Stubby Jr - 37
  • No antenna - 24
After I switched antennas I waited 30 seconds for the signal strength to settle. The truck was parked and turned to ‘on’ but not running. I’m not sure what the measurement is in but the numbers dropped that’s for sure. However, in the end it’s about how well your station comes in.
As for more real world tests, I’ve spent 2 weeks with the Original and 2 weeks with the Stubby... To me they seem virtually the same on my routes I drive. Now I just switched to the Stubby Jr. I guess I’ll see how this works for the next 2 weeks.
Manny
Manny
Here are pictures of 3 antenna options by Cravenspeed. I chose to go with the Stubby Jr. No problems with radio reception with any of the options.
Rinn69
N. Central Iowa
Retired USAF MSgt
I'm definitely going with the rifle cartridge (bullet) one !
DannyL
Danny
Torrance CA
2013 Mustang GT CA Special. Ordering a Ranger Lariat FX2 Supercab in February 2020
Thank you very much for this post. The stock one comes so close to hitting the garage door. I'll be getting the stubby
Rp930
Denver
I should have 4” to spare with the stock antenna.
MT19RANGER
JERRY
SIDNEY, MT
  • Original - 62
  • Stubby - 43
  • Stubby Jr - 37
  • No antenna - 24
How'd you get it into test mode? I tried on mine and it didn't go into test mode. Hold driver side OK button 5+ seconds, then push the start/stop engine button once w/ foot off brake.
Arron
Arron
Seattle, WA
Software developer
On the Lariat with the 501A package, press the seek forward button on the center console and the hang up phone button on the steering wheel for 5 seconds. If it works it will go through the speaker test. Its loud/high pitch so make sure your volume is at a resonable level not to kill your ears.
MT19RANGER
JERRY
SIDNEY, MT
Ah, nice. It worked. Dang, there's a lot of menus in there... All kinds of info that I didn't understand. :)
Had to re-do this - you press the steering wheel skip and the console skip buttons at the same time to get into test mode.
Edit: Someone beat me to the punch while I was testing it out... :LOL: Interestingly enough the signal strength on my stock antenna was 61-64.
THLONE
Thom
Tucson,AZ
internet wise guy
Are any of the antennas rubber, flexible? Can you get different calibers in the bullet antenna?
