- First Name
- Sid
- Joined
- Mar 5, 2019
- Threads
- 67
- Messages
- 9,228
- Reaction score
- 28,562
- Location
- North Carolina
- Vehicle(s)
- 2019 Ranger, 2003 MINI Cooper S, 2021 Honda CT125
- Occupation
- NWO Robot Polisher
- Vehicle Showcase
- 1
There...fixed it for you... ?On the stock wheel and suspension height, 265/70/17 is about the biggest tire you can safely use without issues (Tremor runs this without issue). If you are looking for winter tires, consider function over form. Maybe go with the beef for summer (that’s what she said!).
Maybe the look you want has more to do with the tire design. You had a great off-road/all terrain tire on your last truck. That tire also had an aggressive sidewall. Questionable how much function that adds, but it looks nice. I attached a couple of the common tires that have a similar side profile and are available in the size you already have. The KO2 seem to have the most aggressive look, then the Toyo, and so on…. The more aggressive the look and the tread, the louder the tire tends to be - so prepare for that as well. You are also going to need to choose if you want white lettering (showing) or not. This depends on the tire and the vehicle, and YOUR preference. For me, I am split 50/50. Maintaining white lettering is more work, so I opt for the black side out look.
If you level the front, it seems as though you can go to a slightly bigger tire (wider and/or taller) with maybe only needing a spacer.
