Hi thanks for the response,Hi Nick,
That’s got to be disappointing.
Is the noise there if you rev the engine high while in park or neutral or only when it’s in gear and driving?
Do you know if the UK Rangers have a 2-pce driveshaft like the NA model?
A few of our North American members reported a squealing sound when the centre bearing on their driveshaft was failing. Hopefully, one of them sees your post and will know if that’s the same sound they’ve heard.
That might help some folks on here point you in the right direction. Good luck with this Nick!Hi thanks for the response,
The noise is there when revving in neutral or park, although much quieter.
The noise is also very quiet when listening to it under the bonnet, and much louder inside the cab
Cheers
90%?Mechanic wants to put a new turbo in for £1500 as he’s 90% sure that’s what it is but there’s no chance I’m taking that risk!
Hi Nick,Hi please can anyone name this noise? It happens on any high revs and disappears when the ranger goes up a gear. Is also lessened when towing something. Thanks!
That’s actually a level of certainty tax accounts don’t often give. Accounting in general is often at a MLTN standard, aka at least 50.000001%. A should is as strong as the most prestigious firms will go, 80-90%.90%?
I’d want a lot more certainty than that too. It’s a good thing your mechanic isn’t a tax accountant…”Yeah, I’m 90% sure you can claim that as a deduction.”
Then it’s a good thing I’m not a tax accountant!That’s actually a level of certainty tax accounts don’t often give. Accounting in general is often at a MLTN standard, aka at least 50.000001%. A should is as strong as the most prestigious firms will go, 80-90%.
