LeroyS
- Thread starter
- #16
OK, this is good and I hear what you are saying. The consistent theme being that the car likes hot, long journeys. This is precisely my point as to why I'm confused and annoyed about it as logic dictates that at some point, it will regenerate on the journey and I won't even realise its happening.I work with Heavy Equipment and Semi Trucks, I am very familiar with DPF's and the complete operation of the system as it works in North America. The DPF itself is a ceramic filter that collects the soot from the exhaust of the diesel engine. As the soot accumulates it builds back pressure in the filter(restriction). Once that pressure reaches a pre-determined amount ( set by the manufacturers engineering in order to meet the Emission regulations for the country), the truck will perform a Regen to incinerate the soot to ash, there by rendering it harmless to the environment and allowing it to pass through the filter out into the atmosphere. For a regen to be successful the vehicle has to be run at operating temp for a min of 30 minutes to fully complete the Regen. Any stops in between will interrupt the process, meaning it will have to re-start once all the parameters have been met again. In NA - the EPA set that at 8km/h(5mph), once the truck drops below that = regen stops. So, lets say the truck is set to regen at 90% soot, you go for a long drive and once the engine is up to temp and your moving, its starts a regen. Regen goes for 10 minutes and then you stop = regen stops. If soot dropped to say 70%, the regen won't start up again until it gets back up to its pre-determined amount (90% for this example).
Make sense ? We see issues all the time with trucks that do "short hauls" so they are on and off throttle lots ( builds lots of soot ) and not driven long enough at steady state ( highway) to properly complete a regen. Some of these trucks require a manual regen daily.
I have to go out of my way up some awful road and sit at 47 mph and drive for 10 or 15 mins and it sometimes empties out and you can really smell when it's happening. I get maybe a day or two out of it, go on my journey and its back on again....and even after saying that, I went for what I think is a regen, pulled up and it clearly was regen, the car stunk, the heat was tremendous but the light STILL stayed on.
Is my dpf perhaps just consistently full and my regens are barely even scratching the surface before it fulls up again? I can't figure out why it is doing this and it's really annoying me now as it kills my torque, or is there perhaps a way to tweak my regular drive to get a regen in? My regular drive is circa 60 mph which might be too fast for regen?
