Programming Garage door opener
FX4Offroad
South Florida
2019 Lariat FX4
From old school I guess but...in the interest of safety, I NEVER program my garage door opener.
A thief steals your car, now they have access to your house.
To avoid that, I also program the GPS (home button) to the local police station AND secretly hide the vehicle registration that shows my home address.
Fortunately, the local police station is a few miles from my house so even if I'm on a trip, it will get me close enough to my house. If you don't have a police station close to you use a neighbor's address down the street.
That's just me.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
That's just me.
If my truck is stolen the first thing I'll do [after calling the cops] is erase the garage door memory. Problem solved. But yeah, you make some good points.
Sounds like a plan. Good luck!
Got the remote tonight and that was the missing link. I used the remote then did the learn thing on the opener and it worked the first time.
Thank you all for the info. Seems like that should be more explicit in the instructions. Last time I seemed to recall not having to have the remote when I did the learn function.
Desert_5G
Eric
Arizona
Tacoma
That's just me.
I feel the same way. But I always keep my insurance and reg info in my wallet. That way they are never int he vehicle if its get stolen. As for the HOME in the GPS. Put in a neighbors address you don't like much. That way it gets you close enough to your house w/o actually being your house. :D
Ranger12
Robin
Minneapolis, MN
To program the Lariat buttons for the garage door opener, I had to have the vehicle inside the garage when the "learn" button was pushed. Worked fine then. I had tried to program it from the driveway and it did not work.
RangerCat
Brian
Kansas
I'm glad you finally figured it out. I agree, the instructions were not clear. I thought it read like "program the truck buttons" OR "program the opener motor". Mystery solved I guess.
I even tried this - the truck was sitting right under the opener, but it didn't change anything. It needed the remote to be able to program successfully.
Claudess
Claude
The Plains, VA
Ford
Is this a Lariat only option? Couldn't find any reference to it during the build screens.
MSG W
Kirk
Missouri
2019 Ford Ranger Lariat everything on it but Chrome Package
MT19RANGER
JERRY
SIDNEY, MT
Hi Folks,
I will add something that was really weird. I ended up calling homelink as I could not get the visor to program. The tech at Homelink could not do it either over the phone until she had me unplug the garage refrigerator and the overhead LED lights in the garage. After that the programing worked just fine....Some EMF signals appear to have caused the programing to go astray. Very weird in my opinion....
Ranger Vehicle Engineering,
Ford Motor Co. - Retired
samsd
Dan
2019 Ranger Lariat 4x4, 2024 Honda Odesey, 2024 Street Glide
Took a few try's on mine but got it programmed, agree on the limited range and now curious that you need special led bulbs for a garage door opener, do they interfere with the signal? I have had issues twice with the opener not working and I am sitting in front of it, the wife's T and C is not programmed to this garage but to my son's and she can activate 1/4 mile down the road.
Washashore
JM
Cape Cod, MA
2019 SCab Lariat 4x4
Many of the inexpensive off brand LED bulbs have a high EMI/RF wideband output that can interfere with many wireless devices and receivers (including AM/FM radios.) Here is an article that explains the issue.
https://blog.1000bulbs.com/home/are-my-bulbs-rf-quiet
samsd
Dan
Thanks, that is great info, my house is 100% led, recycled the cfls at Menard's. Time to do some experimenting and see how it operates with bulbs on and off.
Yep, the 2 led bulbs in the opener will cause remote to not function or be intermittent at best. The rest of my garage leds are not a factor.
LarryJ
Milwaukee
2004 Ranger, 1997 BMW Z3, 2010 VW Tiguan
Finally got my door opener programmed today. It was a.challenge and didn’t match exactly any of the instructions I had seen so thought I would post just in case they would be helpful for anyone. I thought it was likely an incomparable Genie door opener so finally I gave up and explained what I had tried in a chat session with Genie Company. Again as I say, it did not match anything I had read, but it may be that the biggest issue was that support person said the truck must be running. He mentioned that even though the manual said it did not, he suggest he has nearly always been unsuccessful if the vehicle was not running. Here are his instructions:
1. Make sure the Ford Ranger is on and running
2. Make sure the garage door is already open and you have access to the Learn code button on the opener (Model PCG600).
3. Go into the running Ford Ranger and clear the HomeLInk code by holding the two outside buttons for 20 seconds.
4. When the ranger LED (on the visor controller) starts blinking the HomeLInk is now cleared.
5.Press and hold the Garage door remote (from other vehicle) and the desired button (to program) on the Ranger at the same time 3 inches from each other, waiting for a slow to fast blink on that button.
6. When it goes to a fast blink...the transfer is complete.
7. Go to the opener (in my case a Genie Chain Glide PCG600.) Press and release the Learn code button, a Red LED will start flashing and you’ll have 30 seconds to run back to the Ranger, where you will press and release the button you trained earlier 3 to 5 times, or until the door starts to wor (up to about 9 times).
My door went up on the third push. It really seems like a combination of the first remote training and the manual programming of the door described in the manual. But all with the truck running. Which was different than the manual. Really shouldn’t be that hard but there are a billion different receivers for door openers. Hope this helps any who are still having issues.
