Homelink - Garage Door Opener
Exactly how I did it when adding. Adding did not trigger a code.
When i get home I can search where I sourced the connector. I agree in not cutting stock harness!
Cool - No codes, this makes it simple then
veedubtuner
Morgan
Tulsa, OK
2004 VW R32/2023 CG XLT Scab FX4 Ranger
VW Parts
lost1
Thomas
2021 Ranger,2018 Chrysler Pacifica
CHAMBERLAIN Smart Garage Control - Wireless Garage Hub and Sensor with Wifi & Bluetooth - Smartphone Controlled, myQ-G0401-ES, White
This is what I installed on my garage door opener. You can open or close the door from anywhere on your phone. I have been using this since I got my 21 Ranger SXT. It just works off of your existing WiFi .
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
They actually work great.
Tom_C
Tom
Virginia, USA
System Admin, Retired
We have chamberline openers in our new house, which come with the wifi/app. The problem I found with them is that they, at the time, didn't want to work with the starlink wifi router. No idea if it's been resolved, but my solution at the time was to get a wifi-extender for just the garage. The extender connects to the skynet (starlink) and the garage openers connect to the extender network. Just don't use the same SSID name, else the opener may try to connect to skynet.
I've since gotten a wifi mesh system and switched over skynet to just be the modem bridge for our house, so I could probably switch the garage over to that, but it's already set up and working, so I'm not messing with it until something happens causing me to make the switch.
BTW, I would prefer not to give Elon my business, but where the house is, besides 1.5M DSL, Skynet is the only game in town.
Muscleford
George
Ohio north coast
Retired CFO
So with this someone could hack into your home network and get into your garage, hmmmmm. That is exactly why I have no smart devices, thermostats,, door locks, refridgerators, garage door openers, etc.
No, not for me!!
As far as the wiring, the Homelink is embedded into the visor and from what others have stated not easily removable so you will need to rewire the power feed for the visor itself. It is just a 2-wire connector. Power & Ground.
Now you have some options here, but it depends on if you have or plan on adding a tapped power source for the (Auto-Dimming) mirror - The popular spot for a Dash Cam (Tap)
As that is the closest spot to tap for (Switched Power)
That Power is Fuse 36 (BCM) it powers after the (Run/Start) Relay closes.
The wire feed comes up the (A-Pillar) to C913 - (Roughly - Dash Level)
Pin #5 = Courtesy Lighting (feeding all the overhead lights (including the Vanity Mirror) Power
Pin #7 = Auto-Dimming Mirror (Power)
Vanity Mirror (Visor) Connector = C907
The best thing would be to get a (Replacement) connector and just disconnect the OE and run a new power & ground source. No damage to the (OE) wiring and then cover/ protect the OE connector and securely stow it.
C-907 -- PN: WPT-1197 (Runs about $45.00) expensive but this will allow the mod to be done correctly and easy revert back to (OE)
or
Disconnect the Vanity (Visor) connector and cut the power feed wire allowing enough wire on the connector (side) for splicing and (resplicing) if wanting or needing to revert back to OE
This is the (Yellow/Green) Wire
If you choose this route, you will only need to splice (power) as the vanity mirror is already grounded.
I always prefer and recommend keeping the OE wire harness intact, when possible, vs cutting into any wire,
So now we need to figure out where to tap an alternate (switched power) source
The closest spot is the Auto-Dimming mirror power, and you can wire down to the C913 connector and (TAP) Pin #7 (Blue/Brown) wire.
Or
Run the wiring over to the mirror and tap the Power Wire There (C9039 - Pin #1 (Blue/Brown) wire
Or
Simply run the power feed down to the BCM (fuse box) and tap a (Switch Power) fuse
The Ground wire if using a new connector will just (Tap) back into the OE wiring harness and if cutting and splicing (at the mirror/visor) Power Only - just leave the ground as is.
As I stated earlier this MAY trigger a fault on the Courtesy Lighting circuit (FET) protection and it will see an open on the circuit, no IPC messages or lights but will show up in a scan of the BCM that's why I recommend doing this modification so it can be easily reverted back to OE as the BCM has the capability of shutting down the circuit (meaning all lighting on that circuit) so all courtesy lighting.
It may not do anything except show a faulted circuit with a BCM scan, so just putting out the possible outcome if you have issues after this modification so you can recover the circuit if needed.
Ref: Auto-Dim Mirror
C913 Location
To Remove the A-Pillar Trim panel, pull the weather strip out and gently pry the trim out towards you.
The Sunvisor - Connector will be accessible when you remove the visor
You should be able to route any wiring as needed without dropping the headliner.
Thanks for all the info airlinetech
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
HERE is how I did mine - I thought I posted something
Could use this to add a second connector that taps off switched power and leave the stock harness intact.
I can answer Qs if needed
