Pics of 265/70/17 tire
Langwilliams
Langley
Lorain, Ohio
do yall run 93?
I did when I had the high octane tune in. I put the low octane tune in for winter. I miss the 25 HPs you lose so in spring I'll go back to the high octane tune. I probably lost .5 to 1 mpg after adding the 265's to the truck. I checked the weight of all the options an the Nitto's are 6 pounds heavier per tire, one of the lower weight options.
sandog
Arizona
2019 Ranger XLT Crew Cab Hot Pepper
Not quite the size the OP desired, but mine are 265/65/18 on aftermarket wheels.
Leveling kit on a 2WD truck. Tires are Mastercraft all season highway tread.
Living The Dream
It's been cold here an I've only done local around town driving an I'm getting a whopping 13 MPG this tank! I've never gotten under 17. I guess it's all the warm up time I've been using.
My avg MPG really drops in the winter, not so much due to the tires or winter blend fuel, but due to me remote starting and letting it run for 5-10 minutes before I get in it.
My average this morning was 14mpg :p
OrangeStreak
New Mexico
Thanks, I was just told that its hard to keep the rake when upgrading to the fox leveling kit or to use blocks on the rear, so I think ill be going this route, saving lots of money as well! How much was your mpg affected?
Freshly installed BFG ALL-TERRAIN TA KO2 LT265/70R17
Great tires! :like:
OrangeStreak
New Mexico
Have put 4000 miles on the KO2's AT (265/70/17). Love the way they handle and ride...much better than the stock factory tires. Aggressive look and quiet. Excellent both in city and on highway. Have the same size spare to go with them.
jflogerzi
Moreno Valley, CA
What level/suspension? Also any wheel spacers?
a fine choice in rubbers! they will not let you down.
those that are getting lower mpg that changed tire size, did you adjust the tire size for the computer and speedo?
i spent about 6 hours today mixed between old state highways and dirt roads / ranch access roads about 30 miles of it was in 4wd and still averaged 21 and change. that included a few right foot misbehaviors and the light to light traffic getting out of the metro mess plus carrying two spares on steels, load e all around the six, full tool bag, assorted recovery gear, full size shovel, axe, recovery tracks, full 52 quart cooler of drinks and food 10 gallons of extra fuel, 2 gallons extra drinking water, air compressor, lawn chairs - the works. i figured eveyones mpg would be around 20.
Langwilliams
Langley
Lorain, Ohio
I changed it with my Livernois tuner.
OrangeStreak
New Mexico
MADPolo
Marco
Tampa, FL
2019 Ford Ranger Lariat FX4
Consultant
KMC Recon 17x8.5 +18mm offset with Cooper Rugged Treks in 265/70R17. Ford Performance FOX 2.0 Level kit. Due to the offset, they definitely rubbed, ended up adding the ReadyLift high clearance intrusion beams.
OrangeStreak
New Mexico
Stock suspension, no level, lift or spacers...the KO2's gave me about 1.5" increase in height overall :)
