Proper Tire Pressure for 265/70/17
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
So my truck originally came with 265/65/18's from the factory. Recommended pressure is 30 psi according to Ford.
I switched to the 17" sport rims, and went with 265/70/17 Wildpeaks. Discount Tire set pressure to 35 psi.
I also switched to eibach front and rear.
The combo of eibach rears, and the wildpeaks + 35 psi, the ride has been pretty darn bumpy. I lowered the psi to 31 psi and it feels a lot better, but the tires visually look "low."
Is it OK to keep these tires at 30 or 31 psi? I kept the front at 35 because if I lowered them to 30 psi, they look low, they have a bulge.
Wanted your thoughts on this guys.
Thank you!
Best way to tell is chalk line them and drive a bit. Look at how it wears off. If even all the way across you’re good. If not adjust accordingly. My guess is you’re pretty close already
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
My stock tires call for 30 and they look a little low, bulge on the side. I keep them at 30-31 and the wear seems even across the tread at 9300 miles.
2.7EcoBoost
NY
2019 Ranger FX4 Screw
What is the load rating? An LT rated C,D or especially E is gonna ride harsher than a SL or XL. I have Standard Load Grabber ATx in the size you mentioned. I set them at 33 psi and with Bilstien's it rides perfect.
VegasRanger
VegasRanger
Las Vegas
Damper Salesman
What is the load rating? An LT rated C,D or especially E is gonna ride a harsher than a SL or XL. I have Standard Load Grabber ATx in the size you mentioned. I set them at 33 psi and with Bilstien's it rode perfect.
These are P rated.
