Oil Catch Can. Yes or No?
task65
TERRYT
MO
2019 Ranger FX4 Lariat
Bridge Builder
I have the MM catch can on my 19 ranger and have a fuel smell from it. I just spray the hoses and can with simple green when I empty it. Does anyone else have that smell? I have read that most catch cans do this and it is normal
VAMike
2019 Ranger Lariat SuperCab
Of course there are liquids going into the engine... that's what vapor is.. fine droplets of a substance and air.
No, that's an aerosol. A vapor is a gas below the critical temperature of the corresponding liquid.
HenryMac
Mech. Engineer - Retired
Actually they are both correct definitions. But thank you for the physics lesson.
VAMike
Even your obnoxious screen shot doesn't support that claim. The words "fine droplets of a substance and air" aren't anywhere in that. Now, if you check the dictionary.com definition of "aerosol" you'll find "colloidal particles dispersed in a gas", which sounds a lot more like what you originally wrote. It's an important distinction, because what you need to do to get a liquid out of a vapor is different from what you need to do to get a liquid out of an aerosol.
HenryMac
Geeze... have fun with all this Mike.
Gixxers
Joshua
2020 ranger
Steelworkers
Yeah its normal, you can eliminate the smell buy using a/n fitting and better O rings.
task65
TERRYT
MO
Bridge Builder
So replace the orings on the two fittings atnthe can or even replace them with better fittings?
Gixxers
Joshua
2020 ranger
Steelworkers
Replace the o rings within the can with the proper one than Replace the fittings with a/n fittings and you will have no smell. Sucks but the company's make good cans but use cheap rings and fitting that are not rated for the what they are used for.
jblc
JB
USA
2021 XLT FX2 supercab
Hmm, good thoughts.
"Replace the o rings within the can with the proper one"
Which one is the proper one?
"Replace the fittings with a/n fittings"
Do you mean, replace all the fittings (except the ones that go to the engine) with a/n fittings?
I had thought that the fittings to the engine were also loose, and so also cause smell. Someone had mentioned adding a 2nd O-ring to eliminate smell, but when I called UPR to ask about that, they said that it was a bad idea -- and that their connectors are the same tightness / looseness as Ford's OEM connectors.
Gixxers
Joshua
2020 ranger
Steelworkers
Hmm, good thoughts.
Use viton o rings, I replaced the fittings at the can with a/n fittings. Like I said good can but cheap components considering the cost.
smell is from the hoses they use. It’s permeable so you smell gas. PTFE lined hoses will not. They can be difficult to work with though so it’s understandable why they supply the non lined hose
billwinkle
Bill
2021 Ford Ranger XLT 4X4 super cab
I just retired from a Subaru Dealer in So Cal. (moved to N.C. as soon as I did) I dealt with Quirt Crawford and Ken Block when he was still racing Subarus. Quirt designed the first catch can for Subis. He found even new WRX engines with oil already in the intercooler. He tried to tell the engineers at Subaru this was a major reason why we were replacing so many engines under warranty. but they would not listen. I think Subaru was a bigger problem than our rangers but I am putting one on my new Ranger just to play it safe.
Yes for my high performance, high output, high reving sports cars...not necessary for my lazy driving style Ranger...
viperwolf
Alex
TN US and PHilippines
2020 Ford Everest 4x4 Titanium BI Turbo, 2015 Ford Ecosport Titanium
Retired Military
First, Love your truck :thumbsup:
As far as CCs go, I would say pull your IC lower pipe off and look. If its dry then Kudos ?, but if the the 2.3 is set up like most of the engines Ive played with. Its probably not dry anymore.
That stuff is being sprayed throughout your intake system, including your turbo if the line is connected that high up the intake chain. Which also includes your throttle body and manifold. I know mine is, and at 400km I already had oil building up. Keep in mind I have a Diesel, but the principle is the same. I use a Provent CC and I have to empty it every oil change. However, my intake system and IC is dry now. :handsinair:
Just pull the pipe and see, it cant hurt anything one way or the other.
Disclaimer: I dont own a 2.3 and never worked on one, so Im sure Ill be corrected if I missed something. ☺
