must mods with forscan ?????
now that i have forscan figured out and did a couple things, what are the must do mods with forscan yall suggest?? i want to try to get them done while i have some time off and ahead of the trail period expiration. it is not that im cheap, im a broke ass. i have a 21 xlt sport fx4 so some of the fancy window, mirror folding and lighting mods are not an option for me. my truck is running sync 3.4
what i have done so far is :
splash screen change
bambi mode enabled
disabled fake engine sounds
open to any suggestions from the group! Thanks
JesseS
Jesse
NorCal (Roseville)
After changing the splash screen I turned off most ALL of those annoying chimes!, changed the 'Panic' activate to a double press as the other keys on the ring would set it off, and changed the 'Battery target state'from 75% to 90%.
Allesky00
Zachary
Louisiana, USA
I&E Tech
How do you disable the fake noises through forscan? I'm thinking about adding a sub to my truck and obviously don't want that going through the new amp.
A Tale Of Two Rangers
Huntington Beach
2021 Ranger XLT 4x4, 1999 Ranger XLT 4x4
Marketing
bambi mode enabled
Courtesy wipe, add extra sweep of wipers after using the washer.
I am waiting for Forscan till I’m bored and nothing else to do, but can you show me what the different splash screen looks like? Can you upload your own photo or is it another Ford one?
here is a youtube video showing the pre programmed options in forscan. I do not have my own photo back ground but would be nice if I could do that. you can change those without forscan but may not stay.
here is a video showing that being done. at one point you had to change number values etc. in forscan. but newer versions most things are simply switching on off.
Disable chimes for when you enter/start. Disable double-honk. Enabled the cornering lamps - turns on one fog light when signalling or turning the wheel (below a certain speed).
thats a good suggestion I will do the cornering lamps! thank you
Tried the corner lighting. It was OK, but kinda gimmicky with my stock Lariat fogs. When I upgraded to amber Squadron Pros there it was too much and turned it off. Would be good with an SAE pocket fog.
Fake engine noise delete
ASS delete
Double honk delete
Tire size change
Those are my big 4
