TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 45
- Messages
- 3,966
- Reaction score
- 9,998
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
- Thread starter
- #631
Battery Life Test Update - July 4th 2025 (9+ months since last test) Previous test for comparison.
Sept 25, 2024 Battery Test Results
2020 Ranger - Last driven 4 hours earlier for 20 miles
Battery Health = 100%
Battery Charge = 79%
CCA = 904 - Rated at 760
Voltage = 12.47v
Internal Resistance = 3.26 mOhms
July 4th, 2025 Battery Test Results
Truck was not driven for 10 days until today. Drive was 10 miles each way for grocery run - 20 miles total. Truck then sat 4 hours before the test. Opening the door activates my Amp Research Power Steps which will deplete any residual voltage overcharge. I am confident in the test accuracy. Both tests were taken using a Viking Battery Tester for consistency sake.
I do own a TopDon Tester. It reported higher voltage, lower CCA, and Lower Internal Resistance.
Battery Charge = 100%
CCA = 889 - Rated at 760
Voltage = 12.61v
Internal Resistance = 3.37 mOhms
The battery is 5 years 2 months old, and is showing no signs of deterioration. I expect at least another 5 years of useful life.
Ambient air temp was 90F. Charge voltage while driving was 13.6v - 13.8v. During winter the charge voltage runs around 14.1v - 14.3v
My dark current drain is minimal. Truck can sit for a month without needing to be charged. I am quite happy with the result. No more supplemental charging required. Just get in and drive, even if it sits for an extended period. Battery life is on track with my other vehicles.
Voltage = 12.47v
Voltage = 12.61v
