IdahoRanger
Thanks all for the quick responses. Yes, I tested fairly soon after the charge.
Excellent Results!So I charged up the battery yesterday and ran a test (12 hours later) this morning. Pretty happy with the results.
Normally I route my charging cable out a seam and close the hood. But the last few times I was lazy and simply left the hood up or unlatched.Yes - Flat Blade to push the hood latch (switch) down
Yes - Neg Cable, I even swapped it over to the Pos (Alt) Feed a few times to see if the reading matched.
For each test result - as the clamp timed out between tests- I pulled (zeroed) and reinstalled.
With the bms disconnected you should also see amperage drop relative to rising soc With the bms in play as the soc level ramps to 100%, the bms should be dropping the voltage as well, most modern smart chargers use 3 algorithm levels of charging , bulk , absorb and float. One of the supposed benefits of bms is to regulate the voltage charge levels to improve battery life by reducing sulfation, but as widely discussed allowing a lead acid battery to consistently charge to less than 100% promotes sulfation. I think periodic use of a desulfator is a more reliable way of maintaining battery health, as I think you may have stated yrs ago batteries would last much longer albeit with fixed voltage system, all one had to do was to check and maintain the cell water levels , parasitic draws were much less of an issue in days of yore.The BMS charging system is at least smart enough to lower charge amperage as the battery nears 100% charge. I let the battery drop to 90% and noticed the AMP at 5-6. By the time SOC was at 97% the Amps had dropped to 2.
You are correct.With the bms disconnected you should also see amperage drop relative to rising soc With the bms in play as the soc level ramps to 100%, the bms should be dropping the voltage as well, most modern smart chargers use 3 algorithm levels of charging , bulk , absorb and float. One of the supposed benefits of bms is to regulate the voltage charge levels to improve battery life by reducing sulfation, but as widely discussed allowing a lead acid battery to consistently charge to less than 100% promotes sulfation. I think periodic use of a desulfator is a more reliable way of maintaining battery health, as I think you may have stated yrs ago batteries would last much longer albeit with fixed voltage system, all one had to do was to check and maintain the cell water levels , parasitic draws were much less of an issue in days of yore.
The only mod I have done, is add an onboard desulfator. My charge voltage ranges widely, day to day, morning to evening. And is quite frequently in the mid to upper 14's. Other times mid 13's, and anywhere in between. Still on original battery.Voltage varied with both ( Sensor plugged and unplugged). Setting to 100% with ASS off in Forscan appears to be similar to unplugging the sensor. My measurement with the ScanGauge 3 is accurate at the battery posts. Charge rate is anywhere from 13.8v - 14.1v
I'm not too worried about it. Sometimes the regen charge works, sometimes it doesn't.If you desire to see consistency in charge voltage disable the bms, otherwise expect to see varying levels impacted by the soc level you have selected as the batt is drawn down then max voltage supplied when vehicle momentum is powering the alternator , then reduced as the soc rises, accessory draw also has an impact.
Love the updates.1) Unplugging the BMS sensor o loses the AMP gauge, and that makes perfect sense as it is a hall effect sensor.
2) I reset the BMS system. This is something that you should do when you replace the battery. I did it on my nearly 6 year old battery. Here's what I observed when I started the truck and drove 20- 30 miles today.
A) Charge voltage dropped to 13.5v-13.7v from 14.1v - 14.2vB) Amps rose from 3 Amps to 9 Amps at 87% charge.C) As SOC climbed to 87% to 92%, Amperage began to slowly drop from 9 Amps to 4 Amps. Voltage slowly climbed from the initial 13.5v - 13.7v up to 13.8V - 13.9V.D) Over time the voltage may change gradually, but Charge Amperage is where the work is done.
It is the SOC set at 75% and ASS enabled. I call it Regenerative Charging Behavior or RCB. Intentionally undercharging the battery in an effort to chase an unobtainable goal... unless the goal is to intentionally prematurely destroy the battery.Love the updates.
I gave up on making any sense of charge voltage. As I have said before, it is all over the map. Today in the 14's driving to my hunting spot. After that, on the way home, it was a constant 13.4ish. I recently again disabled the ASS by plugging in an old useless phone charger. Not sure that affecting anything but the ASS.
