Led Headlight bulbs
MagnetiK
Are any of the low beams available in person? I only see them online.
JimH
Palm Coast, FL
Having read all 35 pages of this thread, I have a question that I didn't see anywhere -- I changed the headlights in my XLT to LEDs and I need to know if the high beams are adjustable?? I've been able to adjust the low beams, but I can't find any way to do the same to the high beams. The way they are, when I switch on the highs, the beam pattern is the same as the lows - i.e. I can't see any further with the highs than with the lows. Any and all suggestions would be appreciated.
When you say the beam pattern is the same when turn on the high beams, do you mean no difference in the amount of light at all? I guess the reason I ask is are your high beams coming on? On high beams all 4 lights should be lit. And the high beams have completely different lens so the beam pattern is completely different. Another totally dumb question is how are you turning you high beams on. Are you pushing the stalk forward or pulling it back? Pulling back only momentarily flashes the high beams. I leave my lights in Auto all the time so they automatically flip between high and low beam as needed.
JimH
Palm Coast, FL
1. The amount of light increases when high beam is selected 2. Yes, high beams are coming on 3. I push forward on the stalk to turn them on 4. I also leave them in automatic. I guess what I'm saying is when the high beams come on, there is more light, but it doesn't project much further than when just the low beams are on. I can't see much further ahead .. can they be adjusted up at all?? Maybe turn the bulbs around??
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I would suspect, and this is complete assumption, that if your high beams are *low* enough that your low-beams are as high, or higher than them, you have an issue with either your low beams being aimed way too high or you have a very serious issue with being lifted too high in the back and/or dropped too low in the front.
NurseNeil
Neil
Winston-Salem,NC
2020 Ranger XLT, SPORT
Nurse
LED fogs came in yesterday, and I was able to find time after dinner/dishes to get out and install them. I thought it was going to be harder to reach up between the crash bar and plastic shroud to get at the fog lights, but it wasn't that bad. The only hard part was trying to blindly find the hole to reinstall the new lights.
One thing you'll notice with these dual color ones (and someone pointed out could be a problem previously) is that they beams don't exactly line up with the stock halogens. The white beam is a little low and the yellow beam is a little high, just because of where the light chips are on the stalk. But luckily (or maybe just by happenstance of the way I installed them) it is that way and not the other way around. I'd much rather have the white directed lower to keep that more intrusive color away from peoples eyes. They yellow is warmer and less hurtful on the eyes, so it shouldn't bother oncoming drivers as much. We'll see though.
Another thing that was happening when I was testing them out was they were being finicky and unpredictable. Turning on different colors (right white, left yellow), or not switching when I wanted them to. But I tried again this morning on my drive into work and they worked as advertised. So I'm thinking it had something to do with the truck being keyed on, but not turned on.
Passenger halogen, Driver LED (white mode)
Passenger halogen, Driver LED (yellow mode)
Both LEDs (white mode)
Both LEDs (yellow mode)
Was it plug and play?? And are those the ones you had a link for earlier this thread?
commbubba19
Omaha
2020 Ranger XLT FX4 - Gots mods
Network Engineer
per my better judgement I purchased some auxito h11 and 9005 bulbs. As I feared the fitment and pattern are horrible.
let’s start with the H11. My first issue was the connector fitment was not very secure. Not sure if this is a tolerance issue on auxitos part but that right there was a deal killer for me. Having a properly securing electrical connection is primary. i did test fit them in the housing and both sides did orient to 9:3 but the hot spot on my wall looked distorted and much larger than the h9 bulb I removed. I did t see any particular glare above the normal cut off but it was difficult to tell. The poor hotspot was the second deal killer for me.
moving onto the 9005 bulb the biggest issue was orientation. It is very important that an led bulb orient correctly at 9:3 in the socket. Even the slightest variation can cause light scatter. Such was the case with these as well. Again no go for me.
so i will stick to halogens until I decide to go oem take off lariat lights or if retrofit source comes out with.
for the love of god please stop putting led lights in reflector housings. They are not brighter. They are not better. Your toilet browsing of Facebook groups and Amazon reviews does not compare to the engineering science behind proper lighting.
Coolbot
New York
2019 Ford Ranger XLT 4x4 SuperCrew
Has anyone tried the H11 100 watt 6000k 20,000LM Car Rovers to see if they fit with the dust covers on.
Not sure why you would want to go that high of lumens on you low beams. As has been discussed in this thread multiple times anything over 12,000 lumens over powers the reflector housing and creates a really bad cutoff pattern and lots of glare for oncoming drivers.
SILK
Ty
Eastern Pennsylvania
2019 XLT Crew Cab Sport, 2018 Santa Cruz Tallboy
IT Director
20,000lm!?!? I hope you step on the SHARPEST of Legos and then also get a significant ticket for blinding the SHIT out of your fellow drivers.
Just looked these up and the chip pattern too wide (2x3) to give a good pattern even if adjusted properly with a reasonable lumen level. Maybe in a projector housing but never in a reflector.
Coolbot
New York
Not too worried about overpowering the housing and cutoff patterns, just wanted to know if they would fit with the dust cover on.
Sorry that you were blinded by another driver but ive seen brighter coming off of jeeps with PIAAs and led light bars
So you want to be just like those jeep drivers who running those illegally on-road and should be ticketed. Sorry but you will be a safety hazard!
Coolbot
New York
Just because there are also other annoying people on the road with brighter and more annoying lights than the ones you're considering, doesn't mean yours won't also be annoying and dangerous for those around you.
From both of your replies i am going to take it that they fit the housing with the dust covers thank you.
I don't know if they fit or not. Actually hope they don't.
