Just updated to Sync 3.4 on my Ranger 2019
TORQUERULES
US
Ranger
An update: Appearently after making FORscan changes, the system needs some time to adapt or pull in changes. Kind of odd.
The splash screen change I made when also reenabling the climate controls was at first only on entry/start-up and the old Ford oval screen was on exit/shut-down. Now the new splash screen is on in both instances.
VAMike
2019 Ranger Lariat SuperCab
Can you take a pic of how that looks like? I’m curious
Not easily, since it only works when the phone is connected and I use a short cable. If you have the built in nav it's mostly the exact same dash display (speed limit, upcoming turn, current road, but does not set eta or remaining distance).
And my song titles came back, must have been a temporary glitch.
BGDOGY
Tommy
virginia
2019 Ford Ranger Lariat 4x4 crew cab
I was hoping to update to SYNC 3.4 this morning, but apparently my Ranger is up to date. It's a 2019 Lariat 501A. Does anyone have an idea when SYNC 3.4 might be available again?
The update is live again for my 2019 Lariat 501A. It was live a couple of weeks ago, but I wanted to give it time to work any bugs out. Went to download it this weekend and it said my 3.3 was up to date, but tonight 3.4.20136 is available again.
treimche
Troy
FORT MYERS, FL
2019 Ranger SOLD. 2005 S2000
Accountant
Thanks for the heads up. Currently downloading the update now!
Timothy Farley
Timothy
2019 Ford Ranger FX4 Lariat 4wd
Wonder if it has the climate control fix. After I did my update a week ago, the website took it down and said 3.3 was the newest. Now it says 3.4 again. Hopefully with bug fixes. Downloading it now.
UofMEngineer
No. Same software as before. Hopefully this has the Delay option in the script to prevent a restart loop.
treimche
Troy
FORT MYERS, FL
Accountant
I should know within 20 min or so if my climate controls disappear. Currently installing SYNC 3.4.
Benworks
Scott
Ontario, Canada
2019 Ranger Lariat 501A Black Appearance Package
Downloaded the version that is once again available and it appears to be the same file. All file names, sizes and timestamps are identical. Strange that now it shows the version as v3.4.20136 instead of v3.4.43 on the website even though they are the same version. If for some very strange reason the new download fixes the climate for anyone is there a way to re-install the same version again? Will it ignore the USB or will it re-install anyways if inserted?
Also anyone with the B&O system notice the volume profile seems to be different or something off? I had everything tuned nicely for my tastes and it seems off..or I need to turn it louder to get the same volume as before with the same settings.
treimche
Troy
FORT MYERS, FL
Accountant
Did the Climate Controls disappear or did Ford fix the Problem?
Very Curious.
Well, if the update would actually work I could tell you. The damn truck turned itself off during the update. I just had the ignition turned on instead of wasting gas while updating. Now the SYNC system won't even start the update process at all. I reformatted the USB drive and downloaded the files again, still won't start the update with the Ranger running or not.
DJRPM4131
Eugene, Oregon
2019 Ranger XLT, 2016 Mazda CX-5
Maybe you should consider Master Reset: From the Sync Home Screen: Settings: General: Master Reset. Of course you'll loose any Customization, but it might get it going again.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
That's why they say to keep it running, unless you're going to sit and watch it, the truck will automatically cut power at a low-power cutoff despite being in the run position in the key. I didn't run mine for most of my update, but I had to run it once in the second half of the update because I got the shutoff warning.
A master reset is probably your best bet.
treimche
Troy
FORT MYERS, FL
Accountant
Master reset of the SYNC system was what it needed. The update was faster with the Ranger sitting idling too. It completed in about 20 min. It gave me an error saying the installation failed, but it actually did not fail. It worked, but I lost the climate controls just like many others. I’ll boot up FORSCAN tomorrow and add them back.
MINI Ranger
Gene
2019 Ranger Lariat FX4, 2014 MINI Cooper S Clubman
ASE Master Technician, MINI Technician, Retired
OK. Yeah, a simple reflash of the same software won't do anything. Did they escalate it at all back to Ford or anything?
You have everything needed to update if you choose to do so.
Well in a weak moment, I tried the update, it never finished as it cycled thru a brief notification that is was done, then would restart, screen would go black, system would come back on and begin updating. I got the impression that it would do this forever. I finally pulled USB..
One of the glitches I noticed was that I no longer have MPG info in the left screen of the instrument panel, it seems to think it's an auto start/stop function. My info screen acknowledges 3.4 20136 PRODUCT version, but maps are still NA 118. I'm still discovering other glitches
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Map version will be incorrect. Sync 3.3 has a bug which did not update the map version. Sync 3.4 fixed that bug but can only read what 3.3 reports for map version and since it didn't get updated due to the bug it may not report the correct map version.. Sync 3.4 will report the correct map version for any maps loaded under 3.4
EDIT: You can verify what map version is installed by looking at the IVSU screen in the diagnostic menu.
