Just updated to Sync 3.4 on my Ranger 2019
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
So I tried to install the official update coming from the unofficial 19200 build. Drove home for about 40 minutes and it still wasn't done restarting so I let it sit for almost an hour and it still kept restarting.
This was on 19200
And this is now
Not sure if that's everything or if I need to try this again...
If you don't have NAV, it'll just keep reapplying the update until you pull the USB stick. It's fine after the first reboot though.
Looking forward to hearing what they do.
Same. Fingers crossed at least.
Bproctor
Bruce
Hickory, NC
2019 Ford Ranger Lariat 2WD
NC National Guard
I created this post earlier. If you are interested in looking at and/or editing a copy of your asbuilt file or forscan download its pretty neat. I found the tools and really liked that I could see more detailed info. https://www.ranger5g.com/forum/threads/fun-stuff.8631/#post-156842
I am also downloading the 3.4.20136 update from cyanlabs to see if that gives me the NA traffic sign.
Edit** Spent several hours downloading and setting this up. Got an error PKG_ERR04 (Package Revoked). Back to the drawing board.
Bproctor
Bruce
Hickory, NC
NC National Guard
If anyone is still trying to download the files from ford and can't, here is a copy I downloaded that doesn't include the license file. I have NAV, so I'm pretty sure it will not work for non-NAV. I'm not sure how the license file works, but I am assuming the update is generic for the most part for NAV and non-NAV systems. Someone please let me know if this is not a feasible idea and I will remove it.
https://1drv.ms/u/s!Ap9kGjPHeeYTg6kHwrR7NjL644BUMA?e=bOCaeQ
Hope it helps someone.
UofMEngineer
This was on 19200
And this is now
EDIT:
I took a look at the USB drive and it appears 9 different log folders/files have been created, each about 7 minutes apart, below are the contents:
You’re missing. The updated -CL voice package. The restart loop is because the script doesn’t have a Delay option at the end. I believe that’s going to get fixed but hasn’t yet.
koly
Ontario
This was on 19200
And this is now
EDIT:
Those interragator logs are produced after each repeated install after the initial one. It's trying to create another XML file each time but cannot since there's already one created from the first install. For the people experiencing the continuous installs without removing the USB, one install is all that's required.
VAMike
2019 Ranger Lariat SuperCab
Mine rebooted a ridiculous number of times and then suddenly was done.
It might be hard for people to be sure it's actually finished since the prompts are so hilariously bad...
koly
Ontario
I went on for atleast 7 or 8 reboots before pulling the plug. Didn't seem like an end was in sight. How many times would you say it rebooted for you? Did you get the "installation complete" prompt where it stayed on the screen for good?
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
Yeah, that's the most confusing SW updater I've ever used. The secret is it's done when it stops and doesn't reboot.
The safest bet for loading the map is to not pay attention to any on screen messages until it stays on the screen and doesn't close or reboot itself.
For those of you with continuous reboots....is there anything else on the USB drive other than the Map Installer?
VAMike
eventually yes. I lost count of how many times it rebooted and was pretty convinced it would never stop. :D
Murphie
Lindale TX
2019 Ranger Lariat 4X2, 2023 Hyundai Santa Fe
Financial Auditor - Retired
Not sure if asked before but those that have lost climate after updating I wonder if you were missing the heated seat controls prior to the update? I updated on my lariat to 3.4 and am also missing the climate icons. Seat control was not showing on mine on 3.3. Just looking to see if a common factor.
I was missing the heated seats icon on my Lariat - and are one of those that are now missing climate controls on Sync 3.4.
VAMike
Missing it where? IIRC it was a config option to have it on the home screen.
Murphie
Lindale TX
Although my Lariat has heated seats, there have not been any controls for them on Sync - not on the home screen, and not on the (now missing) climate controls. The only way to use them was via the hard buttons.
koly
Ontario
Does anyone know if the XML file generated after an install does indeed signify a complete install? Is that proof that the install was successful?
VAMike
well, I had the controls up until the climate screen disappeared, so I don't think it's related.
UofMEngineer
It pulls the currently installed information to punt back to Ford when you upload it. It mainly signifies the install go all the way through.
