How many miles on your 2.3L EcoBoost
paval3
Val
Pennsylvania
2021 Ranger XLT Crewcab & 2003 Mountaineer Premier
2021 XLT Crew, 25,579 miles. Just passed yearly inspection and I was told my Hankook tires (rotated every 5,000 miles) just barely passed and I better get new tires this Summer. Grrrrr Off to search the forum some more for tire recommendations!
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Thats not good!
53K miles on my original Bridgestone Duelers (also rotated every 5K-ish). But when I replace them later this year it will be with Michelins most likely.
Good luck with your tire search!
gfitzge2
Gregg
Louisville, Kentucky
Retired Electrician
2019, 56745 miles. Came home April 15, 2019. Seven year rangerversary coming up in two days. :) Also getting ready for a little road trip to the beach. I still love this truck.🌴🦞🍤
ControlNode
Eastern NC
Computers
My Hankooks lasted over 55k miles. I was planning on replacing them last Oct before my inspection in Dec as the sides were getting.a bit low from not slowing enough for corners, but a razer through the edge of the tread in Sept moved that scheduled replacement up a month. Replaced with XL load rated Michelins.
paval3
Val
Pennsylvania
I have a trip planned in the next couple weeks, so I want to get the new tires before that and not wait until Summer. Considering the Michelin Defender LTX MS2. My driving is 95% paved roads, occasionally in the hay fields to go out and check the hay dryness for baling once hay is cut, so I'm not out in any muddy fields but there may be slight slopes. Low road noise and handling and good on wet roads... decent on in light snow (if it's ice or heavy snow, I don't go out... but never know what I will run into if it's bad when I'm leaving from work and need to get home).
ScarzRanger21(2.0)
Eric
Auberry, CA
Electrician
My 2021 ranger has just under 75k miles, the wife’s 2020 just hit 50k. I’d love to say they’re both running without issue but I’d be lying…
Her transmission needed a rebuild around 35-40k miles, it shifts fine now that it’s been rebuilt. Since we bought her truck, the driveshaft carrier bearing intermittently squeals like a dying pig. The dealership won’t address it yet because “they can’t replicate the noise” when they drive it. They said bring it back when it’s happening consistently. Luckily her has a 100k mile warranty so I’m not too worried about it.
Mine has a rough upshift from 3-4. I need to get the transmission looked at but I’ve been putting it off. If I drive it in tow/haul mode and keep the rpm’s high, it shifts ok. It’s only when I’m not paying attention and let it shift in normal driving mode that it hiccups. If the rpm’s are above 2500 it seems to shift normally. Anything below that, it stutters and slams into gear.
Radioman
Kent
Roseville, CA
Geez I thought I had the lowest miles.
Before my wife passed, I bought her a 2017 Toyota Highlander in March of 2017. It now has just under 19,000 miles. When you're retired and have three vehicles, none of them are driven many miles per year.
TICKLE ZOMBIE
Florence SC
2022 Ranger XLT 2WD Sport
2022 XLT Sport bought new in September 2022… currently at 37,000 miles and that is with having a job at one point for 6 months where I put 12,000 miles on it.
Currently have a job where a company vehicle is provided and parked at home, and the past 5 months only 300 miles of use on my Ranger. 😃
Hope that changes soon though because I really hate my current job more than anything and trying to get out of it. 🤣
15 months of ownership.
2024 xlt, 2x4, advance tow, elocker
You have me beat by 5,000 miles and I've had mine 20 months longer. :shock:
Cabose-1
Eli
Student
I have driven 128k miles in a ford ranger. 40k in my 2020, 60k in my 2022, and 28k in my 2024! Wow, how do you all drive so little? And a lot of miles towing with Them too.
