Fuel in oil
Samsquanch
Maryland
2017 Expedition XLT
Who's knows what they will say, because they don't seem to know or want to know what's going on, my situation was way worse before the HPFP change and that was all their oil changes!
probably time to take it back in and tell them you will be returning until they address it. If they tried to tel me 5.8% fuel in oil was ok I would tell them to put it in writing.
Furthermore, I would ask the service manager if he would mind heading out to the parking lot with you and adding 1.4 cups of fuel to his oil tank and taking you for a ride with him because that’s how your truck is every day at this point.
N. J. Jim
Vineland,N. J.
2019 Ford Ranger Lariat
I will be making a phone call tomorrow!!
JTDay
Josh
Mazdaspeed3, M3
EHS
My anxiety level has increased after reading the latest updates.. best of luck Jim. Be relentless with Ford in your refusal to accept this.
... if your motor does "grenade".... is Ford going to say you voided the warranty by using 5W40?
Well if you look at this web page https://oilincar.com/ford/ranger/v_5-2018-.php it tells an alternative story. So many of the grades discussed would pass the test. Let’s say that a motor did blow because of your suspicion of viscosity. You telling us Ford is going to come back and say warranty denied because you used 10W-40. I think they would just agree oil was in there and that’s not the issue!
HenryMac
Mech. Engineer - Retired
If the vehicle is under warranty, and you care about maintaining that warranty, your best bet is to use what your Owners Manual states... not what some website specifies.
I'm betting every time there is a warranty involved motor failure that Ford does an oil analysis.
MotoWojo
Mustang
Update, I picked up my truck this past Thursday after the latest fix attempt. The dealership replaced the oil separator assembly and also attempted to fix the AC for the 3rd time. All I can say is I am extremely disappointed. First the AC, they claimed that the refrigerant was very low and they filled it up. I asked them if they identified and fixed the leak and they told me they could not find a leak. So after having to refill the refrigerant on subsequent visits, they don't understand that it must be going somewhere? It has been cold here and I am sure that when it gets warmer, I will be without AC yet again. On to the latest fuel in oil fix attempt, after ~150 miles, the oil level is already 1/2 way between the max hole and the twist, which seems worse than ever, as it usually took 400-500 miles to reach that level. About the same level as the 12% fuel dilution sample (500 miles on oil). I monitor several parameters with the Torque app, including the Long Term Fuel Trims. I was quite alarmed to see that the fuel trims were very high and that it bounced around between 11-16 at idle. To me, this would indicate unmetered air in the system and since they just basically replaced the PCV system, I thought they must have not gotten something sealed up properly. After calling the dealership, their tech said this was perfectly normal and that it was due to the adaptive learning process and should be back to normal in 1000 - 2000 miles. Maybe, but I am skeptical. My mileage has also taken an even further nose-dive, as I have been averaging 15.6mpg since picking it up, by far the worst mileage I have aver gotten. Moving on, they said they would give me all the paperwork that has been stacking up, dating back to last September, and that they would include the last 2 oil sample reports including the sample from the 5,000+ miles on the oil that the Field Service Engineer requested. So it turns out that they lost the service records and that they cannot find them in the system, including the last 2 oil sample reports. There is also no record of when the Field Service Engineer and a tech from Ford (Michigan?) travelled to my dealership and ran several tests on my truck. They actually took an oil sample back to Ford........whatever or wherever that means? They said they would do their best to find them, but for the oil sample reports, Ford has no obligation to share those with me. My guestimate based on 3 previous samples, is that the 5,000+ miles sample would be near 20%. The lowest sample I have had to date is 12%, which was taken with only 500 miles on the oil. Sorry for the long-winded post, this whole ordeal has me questioning my lifelong devotion to the blue Oval.
Like anyone could tell even with the best equipment at their disposal with dilution levels like this. It would be like throwing darts blindfolded to quantitatively say it started out as this! ?
Honestly, if they’re having this much difficulty sorting this out over this period of time it might be time to start talking about a buyout from factory and replace it with a working truck that you paid for. You’re going to need to initiate it though. Another member on here did go through that process and got another truck.
HenryMac
Pretty much every oil analysis states if the viscosity is in range, correct? So if the analysis shows high dilution levels, and the viscosity is still in range, that would raise a red flag.
MotoWojo
Mustang
Been there, tried that, Ford denied my buyback as they stated they go strictly by the associated state's lemon law and the Wisconsin law sucks, and I did not qualify. In Wisconsin, you have to have 4 failed fix attempts that all occur in the first year of ownership. My problem did not start until ~10,000 miles and while it started in the first year of ownership, the first actual fix attempt was a couple weeks past the 1 yr anniversary, as I could not get scheduled due to the dealerships around here closing down when the Covid thing started. Wouldn't have mattered though, as they would not have been able to get 4 fix attempts in that little of time.
MotoWojo
Mustang
I don't think that will be an issue? After all the tests people have posted, even those without fuel dilution are showing viscosity levels below the recommended range?
N. J. Jim
Vineland,N. J.
F
[/QUOTE
This is were America is headed, no accountability. Perrty sad when consumers get treated like this. I have a list of companies I no longer care to deal with!!
N. J. Jim
Vineland,N. J.
Yeah but they won't except ours! NICE !! AND THEY MYSTERIOUSLY LOSE ALL YOUR PAPERWORK AND OIL ANALYSIS!
