FORScan Crowdsourced Wiki
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
One thing I'd love to have, but can't figure out if it's possible: an audible chime when I've exceeded the speed limit by my settings, once I've enabled the speed limit sign recognition and set the alert limits. The flashing limit sign on the dash is nice but a chime telling me I'm speeding would be super nice for helping me avoid tickets...any idea if this is possible and if so where to hunt around for the setting?
Sariandan
Kevin
The lowcountry of SC/GA
2022 Ford Mustang EcoBoost
Paramedic/Shift Supervisor
I want to say I saw this in there when I briefly had the sign recognition enabled. I think the reason I didn't try it was that I wasn't sure if it would keep bugging me about it. But then, I disabled the sign recognition anyway.
Think about this... You're driving down the interstate. The truck sees a speed limit sign for 70. All is good. A half mile or so down the road is a minimum speed limit sign that says 40. The truck now thinks the speed limit is 40. If you are tooling along in a 55 mph zone and hit a school zone for 45, the truck recognizes the 45 mph zone. If your school zones are like ours, there is not a speed limit sign at the end, only a sign that says "End School Zone." So now I'm speeding again, according to the truck. These two scenarios aggravated me the most with the sign recognition enabled.
If I think about it, I'll try to take my laptop downstairs and poke around to see if I can remember where I saw the setting.
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
Yeah, so...my Miata does this (chimes for some scenarios when maybe it shouldn't). But it just does a "ding ding ding" (three chimes) and that's it. It's enough to get me to look at my instrument cluster and see the speed limit. I much prefer that. And if I'm driving through a school zone, there is almost always a new speed limit sign within a few minutes, or I'm going to make a turn and thus end the speed limit according to the car, etc.
Out here the interstate signs always have speed limit + truck minimum/maximum speed on the same signpost. So far all my vehicles pick up the actual speed limit from these.
Anyway thanks for looking into it. I should plug in forscan again and see if there's some super secret option in IPC/IPMA...
Sariandan
Kevin
IPC is a good place to start. I’m almost sure I saw it somewhere. OR… I may have simply thought it was a good idea and was looking for it. We’ll see after I get back from my ruck. Gonna load the laptop up with me, so I remember to look when I get home.
reidmefirst
Reid
Des Moines, Iowa
2021 Ranger
Computer stuff
One thing I'd love to have, but can't figure out if it's possible: an audible chime when I've exceeded the speed limit by my settings...
I was hunting for this again and found some other vehicle forums which suggest a solution:
IPC 720-04-01, setting the value to xxxx-xx4x-xxxx, or xxxx-xxCx-xxxx should enable chimes for overspeed indication. Apparently the 'C' value opens up some menu options related to chime settings (possibly chime time, number of chimes, etc)
Source 1: Maverick forums
https://www.mavericktruckclub.com/f...ition-tsr-forscan-mod-confirmed-working.9399/
Source 2: Forscan forums (thread about Ford Focus models): https://forscan.org/forum/viewtopic.php?t=13385&start=30
I will give it a try the next time I think of it. If someone else is interested in this mod and is brave enough to try, have at it =). This is my first automatic transmission vehicle ever, so having it would be nice. I find myself zoning out regarding how fast I am actually going...in my manuals cars I always have some intuition about my speed because I know what gear I'm in and what my engine RPMs are...
For my next trick I would love to see if we can enable Intelligent Adaptive Cruise Control on the trims with the speed limit cameras and ACC. Or, figuring out how to reconfigure the useless right dash screen in the Lariat instrument cluster...
Note: These are the ForScan Settings (My Findings) for those of you who are Upgrading from Factory Halo's to Factory (LED's) and Possibly (After Market LED)
I purchased a Complete Set of Factory Headlamps / Foglamps from Ford Dealer ($2700.00)
It would have cost me more to walk away from As Ordered truck that I waited 7 months to get than a Dealer Ordered Lariat (That Had Them)
I did not want (Ebay) broken tabs on a Brand New Truck
I have a 2022 Lariat - That was Downgraded to Halogen Headlamp / Foglamp at Factory
The Foglamps are on Back-Order, so those are not installed yet
So, I Corrected Ford's deletion of my LED Headlight Assemblies for a piddly $500 Credit.
Here is My Install Notes and Configuration Settings for ForScan:
1. This is on a 22 Lariat that had the misfortune of getting the LED Head/Fog deleted at factory, so it arrived with Halo's
2. In the Install video posted on here, the guy does a quick shot of the Bumper Skirting (outer bolts)
These are located with the head facing forward - if you look up (just in front of the tires) towards the front bumper (you will see them) - Took me a bit to find them
3. The video is correct; the Fender Skirts and Grille are very much a PITA to get loose without patience and finesse
4. Took about 5 hours to get them installed (not including ForScan & Allignment)
4. Now comes ForScan Settings to Make the Lariat LED's Work Correctly, I did some playing with some settings, due to CONFLICTING info on here, that's why I am bringing this to light on my findings to help others on this (upgrade)
I researched 3 Separate Lariat Trim Models - Using As-Built Data to Compare to My Lariat with Halo's
Here They Are:
My As-Built Data (Related to Headlight/DRL Settings - Lariat with Halo's Installed from Factory
BCM
726-26-02 - 0000-0002-0057
726-45-01 - 0A01-0200-0080
726-50-01 - 0280
Lariat As-Built Compare (From 3 Trucks) (All Match these settings) (With Factory LED's)
BCM
726-26-02 - 0000-0001-0056
726-45-01 - 0A01-1000-008E
726-50-01 - 108E
So, I used the 2 recommended GUI Settings at First and this is what I got
In BCM
Allowed DRL Options to (+ Dedicated DRL)
DRL Configuration to (Dedicated DRL)
DRL - Configuration - Changed To (Dedicated DRL) this automatically changes 2 of the Line Codes in the As-Built File Folder (BCM)
726-26-02 - 0000-0001-0056 (Matches my Lariat compare search-As-Built)
726-50-01 - 108E (Matches my Lariat compare search - As-Built)
Now for Allowed DRL Options in GUI, this GUI only adjusts one As-Built File and that is 726-45-01
I had set it to (+Dedicated DRL) but I double checked the (As Built) file and its Hex-Code Read
726-45-01 - 0A01-1F00-009D
So, the Allowed DRL Options (+Dedicated DRL) setting within the GUI, does not change the As-Built File to the correct Hex-Code according to my 3 Lariat comparison trucks.
So, I played with all of the options in GUI, and this is the outcome of each, I will note the changes
on the second set of numbers:
None: 0100
All Options: 7F00
Low Beam: 0300
Hi-Beam: 3F00
Ft Fog: 0700
Ft Turn: 0F00
Dedicated DRL: 1F00
**Incorect Value or Not Configured - 1000 (see below)
Noted: None of These Options gave me my Original as Built (0200), might be due to that I had the other DRL Configuration set to (Dedicated DRL) IDK
If you change the As Built file manually to the (Lariat Compare -Code)
726-45-01 -to - 0A01-1000-008E then look in the GUI (Easy Way) it's listed in a current status of:
Incorrect Value or Not Configured
I may go back in ForScan and Play with the GUI (Options) for DRL Configuration, and see if I can get the GUI format to read correctly (1000) instead of the Incorrect Value or Not Configured
(It's a Curiosity Thing) and I tend to be thorough and meticulous. I'm new to ForScan and Learning
So, I checked Headlight / DRL Operation with both 726-45-01 (1FOO) & ((1000) Hex-Codes
The Headlight's / DRL's work as they should: using both of these Hex-Codes
I decided to manually change and leave this Line Code at (1000) to match my compare trucks
I do not know what the difference between the (2) are (1F00) & (1000) but they both appear to work.
Any ForScan (Guru's) know the answer?
Operational Check:
1. LED Strip - On and Bright
a. With Headlight switch in Auto (Daylight) - So DRL Mode
2. LED Strip - On and Dim
a. Headlight switch in (Headlight) and (Auto - Nighttime)
b. Headlight Switch in Park Lights
c. Activation of Entry / Exit Lights along with Park Lights, Bed Lights, Puddle Lights, Door Locks Activation Etc.
With all that, I also upgraded the Turn Signals to LED as well, while I had it apart. I used the Oxilam 7440 Yellow LEDs from Amazon that others have used and recommended - Man they are BRIGHT
No - Hyper-Blink (at Turn Signals or Dash Indicators)
Before I started my swap, I set up truck at 25' from Garage Door, placed tape across the Top of the projected light source, this way I had a Ref: Line to Adjust them Too, made it so much easier.
Did some other ForScan Mods plus Map Update today as well, so it's been a long day
Sorry, for the LONG Post, but after spending a couple of hours researching the proper Forscan settings and getting conflicting info, I wanted to help others in clarifying the correct settings for swapping their headlights to LED (Factory)
I'm going to post my findings in the Forscan Wiki as well, as they are hidden all over this Forum.
Is it possible to get a Sticky on these settings
EDIT: To Original Post
In BCM (Module) - Easy Way
I went back in and played with the DRL Configuration in GUI (Easy Way)
I attempted to change each of the selections, and it flagged me - not supported
Those Options Are:
0-Not Defined
2-Lo Beam
4- Fog Lamp
8-Turn Lamp
10-Dedicated DRL (The Only Selection That Worked)
32-High Beam
64-Low Beam and Dedicated
So, I'm leaving it alone and deduced it's a ForScan Programming Glitch. It works and that was the end game wanted outcome
I am wandering that since my Fog's is still Halo's has anything to do with it, though. We shall see after the LED Fog's get installed
Thanks
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
Got my Odblinkex today and understand from all the threads here that ignition should be on but not running. Instructions say this:
Justin says...
Justin
NC
2024 Maverick XLT Lux
IT System Analyst II
It would make my day if there was a way to enable transmission temp monitoring using Forscan.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Keep dreaming. It's not exposed to the dash at all.
You can use Torque and an Android device with a BT OBDII adapter, but nothing in the truck will show it.
Sariandan
Kevin
It might be referencing the fuel pump noise that happens when you initially hit the button once, or turn the key to run, but not all the way to start it.
Bsthroop
Brian
New Mexico
Figured it was something odd like that since everyone's worked not running. Was able to make some changes with no problem. Great adaptor and easy process.
Here They Are:
BCM
726-50-01 - 0280
BCM
726-50-01 - 108E
In BCM
None: 0100
All Options: 7F00
Low Beam: 0300
Hi-Beam: 3F00
Ft Fog: 0700
Ft Turn: 0F00
Dedicated DRL: 1F00
Operational Check:
Those Options Are:
0-Not Defined
2-Lo Beam
4- Fog Lamp
8-Turn Lamp
32-High Beam
Thanks
UPDATE
I figured it out and this ONLY applies to Factory LED or Aftermarkets that have a dedicated DRL and that is all you will be using.
Set this option to (16) Dedicated DRL - this will automatically set 2-Lines of Hex Code for you.
NOTE: the (16) is a Binary code that is converted to HEX (Inside of the As-Built) Files
Here are the 2-Lines of Codes it sets
BCM
Now set Allowed DRL Options:
NOTE: The Paragraph at the top
If you have only (1) option for DRL, such as Factory LED Headlights, this will show due to the fact that it matches the (16) Binary code you set in DRL Configuration PLUS
This option ONLY modifies (In addition) (Plus) the standard factory DRL.
So, this normal - As I have not added any special (extra) DRL options to the configuration
So, with this selected, here is the last Hex Line of code that is changed (Automatically)
If you do not see this option (highlighted) then go into the As-Built File and manually change it, then when you go back to the (Module) Easy way, this will be shown
I know there have been quite a few posts on this subject and I wanted to pass along my findings
to clear it up
These are the confirmed settings for the Lariat Factory LED Upgrade, now it should also clear it up for those who have installed the (aftermarket) options. With the attached pics, you can see it more clearly and visualize what changes you want to make
Hope this helps
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Forescan blamed for Battery Monitoring System not working correctly.
Long story to be updated...
Went to the dealer about a month ago because I was receiving the 'system shutting down..." message and ASS not working and was hoping they would just replace the battery under warranty. Dealer ran their tests, replaced the battery and ran the tests again and decided it wasn't charging correctly and needed to order a battery monitor sensor. Part came in and took it in today. I get a call that they replaced the module, but it still isn't charging correctly and noticed the Sync screen was changed and asked if I had made changes with forescan. Busted. I said I did and the service rep told me they suspect the changes were affecting the charging and would need the second key to reprogram everything. She told me they couldn't even get the truck to start now. Knowing that my trail management change would likely be noticed, I took the original switch in also and fessed up to that change. I also told them there was a brake controller installed.
The forescan changes I made and forgive me for not knowing the correct terms... cornering lights, Sync splash screen, speed limit detection, frost warning, off-raod gauges, and the changes for the trail management switch. All were done off the menu items, I didn't change any codes. Never changed the battery charging %.
Now I'm waiting to hear back tomorrow on what they found and hopefully they have it running again.
I haven't ran across any other posts that I remember where the dealer is blaming Forescan changes for the battery issues.
Anyone else hear of any?
Update:
Got the Ranger back with almost all the changes in place. I still don't totally understand the problem but from what I can gather, the BMS was replaced and when they reprogramed something, it didn't match up with the changes I made and caused it not to start. They reprogramed the keys I guess, and got it running. All the changes I had were in place except cornering lights. They didn't even change out the TM switch. I was warned that the changes that were made weren't covered under warranty, but they absorbed the additional time.
Very happy with the outcome. I've purchased from this dealership previously and will be returning back there for service or when I'm due for a new vehicle in the next couple years.
Dahveed
Central Kansas
Pharmacy Consultant
Update:
I've had trouble with my truck always saying "Veh. Charging" as well. I recently replaced my battery and reset the BMS. It was fine for a couple of days, but then immediately went back to doing the same thing. I've only made a few minor alterations with Forscan. I wonder if I should try loading my AsBuilt file and resetting everything.
Update:
I had mine towed in for dead battery. I had made several Forscan changes. Including disabling ASS, splash screen, changing DRL settings,etc. Dealer made no comments about changes. Tested battery found bad and replaced. No charge.
