- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,698
- Reaction score
- 9,002
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
Good, you have at least tackled it.Thanks, they are VLAND/GTR carbide.
They have a DRL pin that goes into the factory harness, or you can bypass the harness and run a separate fuse tap to an "always on" fuse. The tap is their recommendation for non LED rangers, and i don't think anyone in their right mind would downgrade from the lariats. They may be brighter but I think i'd rather have the OEM bulbs if price were equal.
I just changed my allowed DRL to all, and then i was able to set the DRL config to DRL only, and then to DRL + lowbeam (my preference). popping it in neutral, and lowbeam and the DRL light up.
It's interesting - i FEEL like the DRL is dimmer than on the tapped fuse, maybe the BCM sends less voltage? I'll put the harness back in and test one of each once ford replaces my dying battery - i'm trying to give them less to complaining about, as they will certainly take a moral objection to my 12v selector switch for my winch. I could be imagining this, because it's the first day in a week that is bright enough that my lowbeams didn't turn on at noon...
Behavior for DRL seems to be daytime (duh), and in neutral as you describe. I honestly think i'd prefer they run at night. I think that's option B here? will test this evening. Assuming brightness is on parity, seems like the best of both worlds. I can still turn off with the light switch, but always on otherwise.
https://forscan.org/forum/viewtopic.php?t=13865
Finally, i'm not sure what it was doing with the DRL when lowbeams were set, but the DRL ran when i remote started the car (and seemed to be on at night). Oh well.
Now, normal DRL ops, would be - On & Bright - with Headlights not triggered on by (Auto)
and On & Dim - with Headlights triggered on by (Auto) - so yes 50% brightness
and the DRL Conditions - Options makes DRL Full Time Bright, any switch position due to Canada Law requirements (Conventional DRL) and those of us in the USA have (Configurable DRL)
So, at least now it's working, but I think it order to get DRL - Bright, you would have to change the DRL Options off of the (+ Low Beams), BCM sees them on and forces 50% power to the DRL
So as of now you know it works, so set it up how you want it
I now understand the tapped wire to allow the DRL-Bright even with the Low-Beams on, so this may be another option, I don't know what the BCM will do though, might trip fault codes-(IDK)
