Ford Perimeter Plus Alarm system
Hirnlego
SC
2019 Ford Ranger XLT 302A
Thanks!. My eyes are not that good. Had to download the image then enlarge it...can confirm the 2nd A at the end. :idea: Found a killer deal on this kit. Guess I have a veterans day project to complete this Thursday.
Thats the one! You can see it in one of my install images above.
Full disclosure - I cant confirm the 2nd A at the end ?
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
you and me both - I did the same!
Nice find!
Gil-galad
Iowa
2021 Ranger Lariat
Can someone confirm this module part number is correct for the 2019-2021 Ranger, Part number KN1J-19G367-AA.
I assume the kit with the other items wiring harness, jumper, and zip ties is Part Number KN1Z19A361A Ford Perimeter Plus Vehicle Security System.
Definitely the same as mine. Even the bar code is identical.
rfmanning
Robert
Arizona
2020 Ranger
That's what we are here for!
The money part that is. the helpful posts are purely a coincidence!
Well, took the aforementioned part numbers to my dealer last Wednesday. Got a call today, a week later, they were in. Walked I with my 43,000 points. Added $25 to it to pay my way out. Just finished the install. Pretty painless. Seems to work as advertised. Thanks for all the posts and photos.
puckdodger
Oshawa
So I can get perimeter plus for with long range antenna, installed, for about $290 USD after using 40000 Ford Points. My truck did NOT have factory Remote Start.
KN1Z-19A361-A Perimeter plus module $277 USD
JS7Z-15K601-C Remote start system with two 1 Button Remotes $82 USD
JS7Z-15603-A Long Range Antenna $43 USD
Without FordPoints it would bein the neighborhood of $450 USD, taxes and installed.
They didn't break out the install cost from the hardware, is that a fair deal?
Also, do I need to revert ForScan changes I have made back to stock before taking the truck in for the install?
Thanks.
taildraggerpilot
Carl
Kennesaw, GA
2020 Ranger Lariat FX4, 2022 MINI JCW Hardtop, 1967 Mooney M20E
Boeing Guppy Driver
When I was up under the dash connecting the gateway module pigtail, I noticed a purple wire in a harness along the sidewall that was terminated with heat shrink. Anyone know what is up with that?
taildraggerpilot
Carl
Kennesaw, GA
Boeing Guppy Driver
Oh, and I got the “plus” module for $160 the other day.
Waltztj
Walt
2021 Ranger Xl
That part # did not work on my 2021 I sent it back and waiting for the correct part.
Waltztj
Walt
2021 Ranger Xl
That wire is for the tow package. There should be 4 total wires.
taildraggerpilot
Carl
Kennesaw, GA
Boeing Guppy Driver
ok. I guess I should locate and bundle those four wires in preparation for a brake controller install. The other three were probably hiding on the backside of that giant wire bundle.
Hirnlego
SC
What did not work? It is odd how the same model truck has so many deletions and slight variations with software after 2019. This unit did work out on my truck, but it is a 2019 model.
The sensitivity is not nearly as much as I would expect; however, the manual does state it is shock it detects not rocking of the vehicle. Is this what others experience? I have mine set just past half on the dial.
Gil-galad
Iowa
2021 Ranger Lariat
I just kept fine tuning the sensitivity until it matched my expectations. That's one of the advantages of mounting the unit in such a way that it allows easy access to the adjustment knob.
If someone grabs and releases an exterior door handle when the door is locked, letting the spring snap it back into its stowed position, it sets off the "one honk" warning on my truck. Rocking the truck or kicking the tires is not enough of a shock to set it off. I could easily set it to be more sensitive but I like where it is.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Yeah, rocking the Truck does not setup the alarm, tapping the window does. I had mine setup just on the halfway so it's doesn't alarm when a load motorcycle drives by.
MXGOLF
Sales / Photographer
Ok well I ordered one too a couple of weeks ago with some other goodies. I get real heavy trucks driving in front of my house and was wondering if this would get set off all the time?
Thanks for all the help guys!
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
You can adjust the sensitivity level for your liking and environment.
