Tra1969
1FMCU9J90LUB09229 is one example for NA NAV. Basically, if you're missing a file or files, you can look up some used vehicle VINs for MY19/20 with the same system and pull a full package that way. Annoying, but it works.
FYI - A quick way to check if you got the new Voice file is just press the VR button. If all you get is short silence, then the beep to talk you're OK. If it still chimes, or worse, chimes and says "please say a command", you're using an old Voice pack. Gracenotes you can check from the About SYNC screen.
I pulled the file and added it to my flash drive. I did get the chime but it did not say "say a command" I will go try it.
