Ford Officially Releases Sync 3 v3.4 Build 20282
UofMEngineer
However the F150 had 2 additional large files (Gracenotes and NA Language Pack) that the Ranger did not. Took over an hour to update the F150 vs 20 minutes to update the Ranger.
Ugh. What software version was the Ranger on before the update? I've already reported some downloads for Escapes missing those two packages when they should have had them...
tmcolegr
Todd
Central FL
2019 F150 Platinum 4x4 & 2019 Ranger XLT 4x4
Both vehicles were on v3.4 Build 20136.
I thought it was odd the Ranger didn't get the Gracenotes and NA Language Pack updates.
UofMEngineer
*string of expletives*... Yes, it should've had them as well. Something else for everyone to check when they grab the update now.
Have you sent in the XML yet? If not, can you ping me your VIN so I can see what it pulls down for me and report it as well? Thanks!
VAMike
2019 Ranger Lariat SuperCab
I have
0 2020-12-26 13:34 DONTINDX.MSA
25251 2020-12-26 13:34 SyncMyRide\HB5T-14G386-VEB.tar.gz
25266 2020-12-26 13:34 SyncMyRide\HB5T-14G386-VBB.tar.gz
889838273 2020-12-26 13:34 SyncMyRide\5U5T-14G381-EK.tar.gz
593802735 2020-12-26 13:35 SyncMyRide\4U5T-14G423-CB.tar.gz
47192 2020-12-26 13:36 SyncMyRide\GB5T-14G386-AD.tar.gz
540 2020-12-26 13:36 autoinstall.lst
XML already updated.
UofMEngineer
I have
You're missing the 14G391-CM voice pack, unless you had installed it prior.
You win and have all the expected files for a Nav update.
What files should be included with a non-NAV install so I can check my download. I had 3.4 but Ford still said I had 3.3. My install went without issue and I submitted the XML file.
VAMike
If it would have been in the first update for the ranger (sometime last year?) then maybe. My file from July for the 3.4 release that broke climate doesn't have a CM file either.
UofMEngineer
Basically, same as Ranger_Rocks only the C's would be B's, e.g. 14G391-BM. I’ll double check when our power comes back on...
Yep you needed it then. It’s new for this release so the only reason you shouldn’t get it is if you had installed and reported one of the prior MY21 builds.
tmcolegr
Todd
Central FL
Yes I have already sent the XML file.
Both Oasis and the Ford Owner site indicate I have the latest software
Guess no new voice and Gracenotes for me
Traneman
Jay
Rochester MN
2019 Ford Ranger STX 4x4
I have the base XL screen, I see my truck has an update, but havne't update it yet. What will I see with the update on mine?
UofMEngineer
Use the files from the F-150 updater? Can also run another dealer used stock VIN that matches your system, Nav or Non-Nav, and get a new updater.
The little 4? That'd be basically the same as SYNC 3 Non-Nav, only it's 381-FK, 423-BB and 391-BM.
