Fake engine sounds?
Ok I have some ?'s about this "fake engine noise". Does it come through the radio speakers or is there some hidden speaker some where? Does it happen instantly at start up while still in park or neutral, or do you have to be in drive & moving? Like if you are setting still in neutral & rev the motor does it change sound? Does it change as you drive with engine rpm & gear selection? After I get some answers I will give my report. ?
Comes through the radio speakers, especially through the sub if you have one. Yes it is there all the time and changes with RPM as you go through gears.
You will not believe how much quieter the cab will be in town. If it was piped outside, it might be more fun.
Blue Streak
Larry
If this is true I stand by my first reply. Mine does not have it. :clap:
mlarma
2020 Ranger XLT 4x2
Computers/Networks
Is the fake or simulated engine noise only in the B&O sound systems? I have a 20 XLT Sport 4x4, 302A package and I don't hear it. Not that I want to but thinking of adding a sub and don't need or want simulated engine noise through the sub. Thanks for any advice.
It’s there. I got rid of my fake sound with forscsn and I have a 20 XLT FX2 also with the 302A and tech package.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Wonder if the fake sound is only with the B&O system . . .
It's not. I don't have the B&O and it was there. People who think it's not there haven't actually tried to disable it.
Blue Streak
Larry
True have not tried to disable it. Also I have no need for Forscan. Also if answers to my previous post ?'s are yes as Gizmokid stated, then I still say my truck does not have it. ? Unless some one can come up with a better explanation of how & when fake engine noise operates I still say no.
TN Ranger
2020 Ford Ranger
Electricain
I'm with you. I've tried revving the motor setting still, running hard down the road, and all sorts. Still I don't hear it. Maybe I don't have the best hearing but my truck is pretty quiet. I've been thinking about an aftermarket exhaust just so I can hear some noise.
I find it really amazing that prior to us having a way to disable it, a lot of people were complaining about it being there, and swearing it was really there. Now that we have a switch to disable it, all these people swear they don't have it. I don't see that Ford would randomly disable it. I guess if you don't think you have it and are happy, fine. If you think you have it and want to hit rid if it, disable it and be happy too. If you are curious, try it both ways and see. Then set it the way you like and be happy. We should all be happy! ?
I have a lariat with the sound upgrade. Engine sounds normal at normal Temps. But if it's cold, the fake engine noise enhancement makes my truck sound like a V12, it's incredibly stupid. I plan on having them remove it in Ford IDS. Would do it myself, but the Ford software is $99 plus requires a subscription. The car dealer said its mandatory, and makes the engine sound nice. I highly disagree.
Forscan is free and how to do it is listed on here. Not to mention a myriad of other things you can tweak yourself. It’s really worth learning how to do it as you can pretty much tweak any Ford using it.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
That's been my take. I knew it was a thing, it existed on my Mustang too. Would I have really noticed if I'd never heard about it? Almost certainly not, but that's because that's exactly how it was designed, so from a driver/passenger's perspective, it was completely seamless and you don't think about it.
Having it disabled in the Ranger has made my truck significantly quieter, even people who didn't know about it made a comment about the sound difference before and after without being prompted.
MikeyTX
Big Bend Country, TX
'21 Lariat Supercrew; '21 MX-5 Miata
Retired Military/Law enforcement
I was skeptical to, until I turned it off and was amazed how much quieter my SCAB was around town. Still have some wind/road noise on the hyway but night and day in town. Also turned on ANC (the next item down on the list). Mine was off.
ANC is not on by default ? Sucks .................
MikeyTX
Where are these vents you speak of ?
MikeyTX
Ahhhhh Soooo .......... :clap: Yes, they would allow for the air in the cabin to exit using vacuum to prevent the windows from blowing out at hypersonic speeds. That which I shall obtain once I've installed the Ford Performance tune on order with Benny. :rockon:
MikeyTX
Does ANC cancel out noise from the rear vents ?
Uh ................. If you can hear the air pass thru the rear bulkhead cabin vents, who is in the driver's seat ? And, have you stripped all the sound deadening material along with the second row seats from the cabin ? ;):D
Barend Steyn
Barend
South Africa
2020 Ford Ranger Wildtrak 2.0 BiT 4x4 D/C
Mining Engineer
Hi,
I managed to switch off the fake engine noise in the '20 Ford Ranger Wildtrak 4x4 2.0 BiT D/C RH drive using Forscan and OBDLinkEX (recommended by Forscan). RH drive units seem not to have the switch avaialable, HEX code to be adjusted. See images attached.
Hope it helps!
