Do I need to replace my thermostat?
Metal Geezer
Thom
Fredericton NB Canada
2020 Ranger XLT FX4 Off Road
Any others experience this?
As my engine warms upon my 20 minute drive to/from work, the temp gauge rises to “about” 1/4, then falls back to almost C. Stays there for a while, then slowly recovers to normal operating temperature just below 1/2. I can feel it in the cabin air temperature as well.
(Apologies ahead of time for the suspect picture quality)
LawnMM
Rich
'23 Ranger Tremor
Possible, it might be getting stuck open. I can look up the check process tomorrow but Airline Tech will probably be at me to it
Andrew27
Andrew
Missouri
23 Ford Ranger, 95 Ford Explorer, 98 Ford Ranger
Auto Technician
Make sure your coolant level is full first. If so, replacing the thermostat would be the next step in my opinion.
Could be stuck open, but I would check the coolant level & pressure test the system (If low)
including the cap.
Fluctuating gauge - could be low coolant and or air pockets in the system, but being it never reached operating temp - most likely stuck open T-Stat, not as common as stuck closed, but it does happen.
Metal Geezer
Metal Geezer
Thom
Thanx for all your input.
I have verified that coolant is just below “max” in the degas bottle, but I don’t have the tools to pressure test.
On tonight’s drive it behaved normally after 3 consecutive days of foolishness. (This happened a couple of times last winter but more randomly. Normal when I took it to the dealer of course). ?
I’ll likely change thermostats when the weather warms a bit.
Thanx again!
Colo_Ranger
Thanx again!
Just for reference sake, the coolant has been low in every Ranger I have seen (from the factory). You should top it off, no matter what. I wouldn't consider that to be a leak...
Blue Streak
Larry
Back in the 70s we put 3 thermostats in my dads 74 F150 in 3 days. He had a 60 + mile drive home every day & this was the winter. Fortunately they all stuck open. :headbang:
Ahhhh, the 70s - the days of changing thermostats every Spring and Fall. That’s when I learned how not to tighten down a thermostat housing. ?
Dereku
Chicagoland Area
I had a few thermostats back in the day that might have had a single oversized bolt or if I could a through bolt and nut lol
ronranger
Ron
Tulsa
2020 XLT sport 4x4
adventure
In cold weather my thermostat works a lot like yours. Good luck.
Grandaccess
Binghamton, N.Y
Computer Consultant
Mine too, I never thought anything of it, it never gets to half way
Kawffin
Marlow
Palm springs, CA
2019 Ford Ranger XLT
Cultivation technician II
Im having this same issue but mine is throwing a check engine light. My thermostat was replaced last year by the dealer so im guessing it's a faulty thermostat.
RangerBill
You should read the DTC codes and report them here.
RangerBill
Could be a bad thermostat. From the shop manual:
Gasoline Engines PCED
P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
Description:
This DTC sets when the thermostat monitor has not achieved the required engine operating temperature within a specified amount of time.​
Possible Causes:
  • Insufficient warm up time
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Damaged engine coolant temperature (ECT) sensor
  • Damaged cylinder head temperature (CHT) sensor
