Biggest tires, no lift?
doug910
Detroit, MI
'19 Ranger, '02 BMW 540i
In response to spare… I also didn’t replace spare and got 265/70/17. I noticed the spare is 255/70/17 (which i find really odd considering the stock tires are 255/65/17).
So will my spare work with 265/70?
Yes, spare will fit. That's the stock tire size for Tremor.
ben8jam
Ben
Los Angeles
2019 Ranger XLT
Actually i got that wrong, the spare is 255/70/16 -- Need a tired that matches 265/70/17 but on a 16" rim for the sparee.
doug910
Detroit, MI
Oh, in that case you'll need 265/75R16. That will have the same OD as 265/70R17.
Fritz
St.Paul
2019 XL
265/75r16 on stock suspension / slight rub due to wheel offset
Are those stock 16” wheels?
I want to keep my 16’s. I read this entire thread and 16’s are referenced only three times.
I assumed 265/75r16 will fit a stock truck on stock 16”wheels.
My current 235/85r16 fit fine but it’s time to switch to summer tires.
ulric
Ulric
Canada
2020 Ranger XL
Military
These are Taco rims. If I had the stock xl rims I would go with 235/85r16s. I'm thinking the 265s might rub on the spindle. My summer tires are 265/70r17 on STX mags and they had a quarter inch of clearance so I switched to 17inch steelies.
VESH
2019 FX4
Confirming 265/75/16 wildpeak fit on stock wheels, crash bars in tact etc etc. Eventually lifted ~1.5 but I had no rubbing at stock height
Fritz
St.Paul
2019 XL
Looks great, thanks.
BMalm
Brian
Manassas, VA
Ford Range XLT
Your truck looks great. Mind if I ask what wheels are those?
Fritz
St.Paul
2019 XL
265/75r16 Goodyear ultra terrain, load range SL. Pictured next to my winter 235/85r16 Firestone winterforce.
Aonarch
Alec
North GA/ Montana
People here need a lesson on IFS and tire size.
33" is the max I'd rock on a Ranger no matter the lift on the stock arms. You can only lift an IFS vehicle so high with the factory control arms and subframe. Maximum travel is set in stone. The exception would be an extended travel coilover and a UCA, but you might get an inch of additional, we aren't talking 5 extra inches. Maybe more, but you will eventually bind, which is bad.
If you go with an APG or Bajakits extended kit, then you can go above a 33, because the geometry is different. Think of a pendulum. The factory arms has a fixed amount of travel. I'd then argue with anything bigger than a 33 on our front diff, you will increase the wear and tear and the probably something breaking offroad.
Lifting IFS just reduces your ratio of down travel. So lifting an IFS truck will allow you to fit a taller tire sitting still. But once you articulate, that is when the tire might no longer fit (Scrubbing, rub, binding). So right now, you can fit what ever size tire you want that can sit inside the wheel wells as long as you do not have any suspension travel, aka a SEMA build.
I could talk about this for 30 minutes at least.
But here is an example:
Say the factory front suspension has 10" of total travel. 5" up and 5" down. You then put a 2" topper spacer (Strut spacer), all that does is push your suspension further down it's travel arc. So now you have 7" of up travel and 3" of down travel, still only 10" total. You might now need an upper control arm to correct for camber and caster.
^ note I didn't say coilover or shock. Travel is determined but the combination of all of the parts, the arms, the CV, the tie rod, and the coilover.
An extended coilover, could grant you additional travel, but then you might end up binding something, whether it's the CV, tie rod, UCA on the coil bucket, lower control arm, etc.
The absolute worst thing to bind is the upper ball joint.
Note: I am not saying that an extended coil over does not work with our trucks, they do grant you a tiny bit more of total travel.
For record I've had several Jeeps on 37"+ tires.
I've had three IFS trucks on 33s.
