Biggest tires, no lift?
Looks Stellar! I was contemplating those rims on my stock truck as well with 265/70 but was worried about the extra rim width. Thanks for confirming!
Is your load C or E KO2s? Also where did you order your raptor wheels from?
You can get the Raptor wheel here on eBay.
DerangedPony
None
None
Thank you! They are E only because I wanted the 3 ply sidewalls and I think they ride great. Got the wheels at Summit Racing. They were the cheapest to begin with and then they had another $50 off for Black Friday. I think I got them with all 4 TPMS and the tool for $770.
Edit:
Here's the link - https://www.summitracing.com/parts/FMS-S0004
levimac`
levi
oregon
2019 Ranger super crew 4x4
Hi Levimac. For reference could you post what your offset was on your wheels. Just trying to figure out tire and wheel combo that are ideal for our trucks.
Okay, the tires I have are the 245/70/17 maxxis big horn MT load range D , the wheels are ultra nemesis 17x9 6-135.5/5.5 and the offset is +18mm and the back space is5.7 ", according to the manager at Les Schwab tire store in Ontario Oregon.
I keep 35 psi in all 4 tires also, and I like the ride but I am a truck man so a little harshness is great and the 35 in my opine is just right any more , like 40 is to hard and can cause the truck to wonder a bit, and 30 psi can cause a bit more tire wear on the out side, but as always , to each His own, I had a 17 Tacoma and with 40 it wandered like crazy and they were 265/16/16 MT and or AT's , I tried both styles, my Tacoma was an SR5 not an off-road 4x4 that is the truck I ran 35 lbs in the tires so I stuck with that on the Ranger also.
BRanger
Beau
Baton Rouge
2021 301a XLT Cactus Grey
Has anyone tried 265/70r18? Stock width 10.4" but 32.6" tall. Crash bar adjustment may be necessary? Maybe add spacers to drop offset from +44?
MotoWojo
Mustang
https://www.ranger5g.com/forum/threads/towing-a-19-airstream.4291/page-2
In the post above, a member has 265/70R18 on the stock wheels with no lift, and with the crash bars in place. After reading that, I purchased a set of 265/70R18 Falken Wildpeak AT3Ws.
I am hoping I can keep the stock height, But I plan on putting on the Eibach suspension front & rear and I will wait until I have those to install and mount the tires, just in case. I ordered the Eibachs on Black Friday from Stage 3, but they have screwed up my order a couple times and I am less than impressed with their customer service. Hopefully, they will get it sorted out, but from the conversation I had with them, it may be over a week before I get an RMA and can ship back the shocks that were shipped incorrectly and get the correct ones on order again.
BRanger
Beau
Baton Rouge
Thanks for the link! Personally I like some rake on the Rangers. A 1-1.5” lift on the front with some larger tires would look great.
Reactions: EJH
Arch Stanton
Reno Nevada
2019 Ford Ranger XLT FX4 4x4 Ingot Silver 301A
V.P. of Research and Development; Telemetry and Guidance Testing Facility at Aerodytech Corporation, Reno, Nevada
Given there's ~1/2 inch clearance, do you think a 275 tire at 10.8" wide vs. 10.4" for the 265 would fit without contact?
Hi, was wondering if you were ever able to get an answer to you question? I too am looking at 275/70r17's with a 2" lift. Seems like most people want to jump up to the 285's and do some trimming, I think 275/70's would look fine though and maybe avoid all that.
Thanks!!
IdriveG5
NC
Ranger FX4
FYI. For anyone that is going to loosen and move the stock front intrusion bars to get a little extra clearance. Check them for how much space to the bumper with your finger before you Hercules loosen them! I only had to do the driver side, the passenger side was already pushed forward all the way!
Ron Gillette
RG
Kissimmee, Florida
2019 Ford Ranger XLT Sport
My 4X2 XLT Sport goes in Monday for a 2.5 lev-kit and new 6-ply LT275/70R17 Falken Wildpeak AT3W. Also getting the new NFab Epyx series textured black step bars added. I’ll let y’all know how the 275’s do.
Stock stance attached.
Arch Stanton
Reno Nevada
Sounds good, looking forward to seeing it!!!
@zzzziegler
Jarret
Wichita, Kansas
2019 Ford Ranger lariat Fx4
Plumber
I also had problems ordering my Eibach from them. I only received one front shock.
TKDMasterV
Pooler, GA
2019 Ford Ranger Supercrew XLT - Sport
i get my BFGs Tuesday. Interested in your fit, be sure to post. I am scared ill need 1/4" spacer and will have to wait until I get them.
Here is mine with NFAB and 3" level stock tires.
Arch Stanton
Reno Nevada
Is that 3" front and 1" rear lift?
TKDMasterV
Pooler, GA
Arch Stanton
Reno Nevada
Just 3" front
Curious what your step bar measures to the ground at each end with the 3" kit? Is it a bit higher in the front?
