Neil S
I added the AVS Bugdeflector II to my Lariat today. I used the AVS pins and they seem to hold tight. I do like the lip and the overall contours.
Congrats on getting your truck. You probably saw my Saber Lariat when you picked yours up. I was on a fishing trip when Russell texted me that they had been delivered. Will be picking it up tomorrow after work.Looks good - that's what I'm getting on my Magnetic Lariat, but I'm having it put on at Line-X where they're doing my cover and bed liner. I'm not handy and i did not think $50 was too much.
Mine is not here yet. I think I did see yours last Wednesday when I got back from a auction pick up for them....Terry was struggling to use the app to unlock yoursCongrats on getting your truck. You probably saw my Saber Lariat when you picked yours up. I was on a fishing trip when Russell texted me that they had been delivered. Will be picking it up tomorrow after work.
I am a tool junkie. I opted for a set. Might come in handy when I install my brake controller.If you purchase one of these, you'll find removing the hood gasket pins easy!
https://www.amazon.com/dp/B0734VKNYK/ref=dp_cerb_1
Where did you get the tool??Ordered my AVS bug shield Tue 23rd estimated delivery 7-30/ 8-2. Received it yesterday. Did the install this morning time to install less than 1hr. This is my procedure.
1 deburred holes in bug shield
2 cleaned leading edge of hood
3 placed a moving blanket over engine bay, if you drop a pin it may be hard to locate if ever located, they only supply 8 that are needed
4 test fit bug shield and mark hood with chalk to locate pins that need to be removed
5 remove pins
6 reinstall bug shield under rubber and locate holes rubber will hold it in place
7 insert new pins be sure pin is fully inserted before setting the screw
8 clean chalk off hood
As far as I am concerned the pin tool remover is a must have
That's my story and I'm sticking to it
Very nice procedure and install. Looks great.Ordered my AVS bug shield Tue 23rd estimated delivery 7-30/ 8-2. Received it yesterday. Did the install this morning time to install less than 1hr. This is my procedure.
5 remove pins
Washashore has this link to Amazon in his response I clicked it to check out the tool scrolled down & there was more listed. I went for the MANFITTER 38pc set. Like I said I'm a tool junkie.Where did you get the tool??
Thank you.Very nice procedure and install. Looks great.
Tod. Looks good. It looks like yours from what I can see has an AVS sticker on it like others I have seen. Mine did not have a sticker but it has the AVS engraved. Yes the tool is a must.Installed the AVS Bugshield II today. Took all of15 minutes using supplied fasteners. Key was a removal tool. Pops the OEM right out.![]()
I really didnt look close at it....but i think it is more of a stick on emblem than a sticker. I will look closer tomorrow.Tod. Looks good. It looks like yours from what I can see has an AVS sticker on it like others I have seen. Mine did not have a sticker but it has the AVS engraved. Yes the tool is a must.
