AVS Bug Deflector (photo)
Neil S
Neil
TN
2019 Ranger Lariat FX
I added the AVS Bugdeflector II to my Lariat today. I used the AVS pins and they seem to hold tight. I do like the lip and the overall contours.
Richard Conley
Rich
Geneseo, IL
2019 Ranger Lariat, 2016 Honda Accord Touring
Looks good - that's what I'm getting on my Magnetic Lariat, but I'm having it put on at Line-X where they're doing my cover and bed liner. I'm not handy and i did not think $50 was too much.
Caliope
Lisa
IL
2019 Ranger CC 4WD Lariat, 2022 Bronco Sport OB
Congrats on getting your truck. You probably saw my Saber Lariat when you picked yours up. I was on a fishing trip when Russell texted me that they had been delivered. Will be picking it up tomorrow after work.
Richard Conley
Rich
Geneseo, IL
Mine is not here yet. I think I did see yours last Wednesday when I got back from a auction pick up for them....Terry was struggling to use the app to unlock yours :) Mine is scheduled for delivery next week - getting them to put on a cat-back exhaust and letters on the tailgate, then over to Line-X for bed liner and cover along with the bug deflector.
Blue Streak
Larry
Blue Streak
Larry
Ordered my AVS bug shield Tue 23rd estimated delivery 7-30/ 8-2. Received it yesterday. Did the install this morning time to install less than 1hr. This is my procedure.
1 deburred holes in bug shield
2 cleaned leading edge of hood
3 placed a moving blanket over engine bay, if you drop a pin it may be hard to locate if ever located, they only supply 8 that are needed
4 test fit bug shield and mark hood with chalk to locate pins that need to be removed
5 remove pins
6 reinstall bug shield under rubber and locate holes rubber will hold it in place
7 insert new pins be sure pin is fully inserted before setting the screw
8 clean chalk off hood
As far as I am concerned the pin tool remover is a must have
That's my story and I'm sticking to it
Hounddog409
Tod
Ohio
F150
5 remove pins
Where did you get the tool??
MT19RANGER
JERRY
SIDNEY, MT
5 remove pins
Very nice procedure and install. Looks great.
Blue Streak
Larry
Blue Streak
Larry
Thank you.
One update on install. The clearance between the shield & the hood (on mine) did not require the use of the clear bumpers on the hood.
Defender
Altoona, Iowa
2010 Mazda6
I purchased and installed the Ford deflector. Took a little over an hour. Have to admit, I was nervous putting those clamps/brackets on the hood lip. I was afraid I’d scratch the hood. Ended up looking really nice.
Blue Streak
Larry
Installed the AVS Bugshield II today. Took all of
15 minutes using supplied fasteners. Key was a removal tool. Pops the OEM right out.
Tod. Looks good. It looks like yours from what I can see has an AVS sticker on it like others I have seen. Mine did not have a sticker but it has the AVS engraved. Yes the tool is a must.
Hounddog409
Tod
Ohio
F150
I really didnt look close at it....but i think it is more of a stick on emblem than a sticker. I will look closer tomorrow.
I got the tool at the local autozone for like 9 bucks. Called a door panel remover. Green handle.
The shield is the AVS bugflecter II.
