Auxillary switch panel
Nat
Jordan
New Mexico
2023 Tremor
Army
this a stock aux switch option, came on my Tremor, and wired to aux fuse box/harness. Maybe ford accessories has some kinda option?
Colo_Ranger
Hello, I find this switch panel on the internet. Where can I buy this component?
This is called the up-fitter switches. They are factory on the Tremor, In the States, there is no part number and the part cannot be purchased separately. It appears you're in another country, so you may be able to find it at a dealer, but we cannot get it.
SVTPaul
Newfoundland, Canada
2021 Ranger, 2004 SVT Cobra, 2008 Subaru STi
Depending how much you want to spend, the Trigger 6-Shooter is a nice option to check out. It has a wireless controller unless you want switch backlighting (I did), and even then just a single light gauge wire pair to the base. The switch bank sits on a magnetic base so you can take it outside the cab and use it. No wires to pass through the firewall and looks like a factory option. Love mine :)
KYFord4x4
Aaron
Kentucky
2019 Ford Ranger Lariat 4x4
Auto worker
I know this is an older thread...but...
Is there an easy way from the top of the dash, where the tray is, to run a wire down so I can install an accessory (USB) power point or switch panel? I don't see a feed through point, can't see any light coming out the top when I put a flashlight under there. Would I have to run the wire across to the feed through for the A-pilar?
Here's a couple of threads you can look through. They should have the pictures and areas to tap into that you're looking for to run the wire.
https://www.ranger5g.com/forum/threads/dash-tray-removal.3178/
https://www.ranger5g.com/forum/threads/dashboard-wire-routing-help.26475/page-2#post-609531
https://www.ranger5g.com/forum/threads/wireless-charging-install.2704/page-2#post-166996
veedubtuner
Morgan
Tulsa, OK
VW Parts
Actually you can buy just the switch panel, it's just pricey ?. As far as the wiring and fuse/relay block, that may need to be custom.
Colo_Ranger
When I posted that… you couldn’t. Lol
amazing how proud they are of that switch though.
LawnMM
Rich
'23 Ranger Tremor
You can buy all of it now, I believe, but it's several thousand bucks total if I remember when I did the rough math. Like more than the Tremor package costs when you're buying the truck...
You're better off adding an aftermarket switch/button panel and running some wire and some relays and fuses yourself.
There are several members here with pretty sophisticated setups.
Yea I didn't notice how old the post was till after lol. My bad.
Don't feel bad Morgan Paul @OrangeStreak loves to resurrect 4-5 year old threads too. The last one was a 4th of July thread from 4 years ago thinking it was the current year one. ?:crackup:
