Front Door Panel Removal
If a MOD sees this. Can you re title the thread.
All Set. I too was wondering why you wanted to take your doors off? :D
i want to drive doors off, so i too was interested in door removal
Hi RP,
When I see a Taco....I want to blow ITS doors off. Usually not a problem to do....
JDowns
JDowns
Coeur D'Alene
2021 Ranger XLT Tremor
This is covered in the door panel removal video but just a reminder.
When removing the door latch mechanism do not pry on the housing as the clip is very small and would be easy to break. If you look just below where the cable enters the housing you will see a press in retainer clip. Just push in with a small flat head and the housing will pop up on its own with no need to pry.
While the video doesn't cover rear door panel removal its essentially the same, with the only difference being the arm rest cover being two pieces, where the top piece is removable. Start at the bottom and work your way up. At the very top there is a round plastic insert (non clipping). If you gently lift the cover upwards it will pop right out of its housing.
If your vehicle was like mine there will be an extra electrical connection to remove for each door. My vehicle had a capped off two wire connection attached to the door panels. Most likely for a security system vibration sensors.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
Did you dynamat the doors or install aftermarket speakers (or both)?
I think the dynamat is going to be necessary this spring but didn't know if while things were apart to replace the B&O speakers.
JDowns
JDowns
Coeur D'Alene
I put a roughly 8x8 piece behind the speakers. I never found the doors to really need any sound deadening. There is foam between the door panel and the door attached to the door with insulation on the door panel.
I upgraded the stock speakers with Focal IS Ford 165's.
2021Ranger
Barry
NJ
2021 Ranger
Not to derail this but if you remove the cover behind the door panel is there enough room to put some sound deadener in there? wanting to get rid of the tin can sound when closing the door..thanks
veedubtuner
Morgan
Tulsa, OK
2023 CG XLT Scab FX4 Ranger
VW Parts slinger
Around the 17:30 mark, they show where they applied some sound deadening material :like:
Here
XLT
On Ranger5g.com, old threads never die. They still have life, still add value.
:D
