Air Dam Delete? Mod your old air dam to fill the gap
Just did this mod today, took about 45 minutes. Well worth it! Thanks for the write up
That’s great. I wish there was a free t-shirt I could hand out for this mod.
Done!! Thanks for the idea!
Some differences in my approach: I left the bumper cover on and never removed the dam except for the outter 6 bolts. Used painters tape to trace my lines and cut with a soldering iron with a hot knife attachment. Much better looking than than stock!
Oh and I added door edge trim to the upper lip of the skid plate
I just had these printed up - welcome to the exclusive club. Wear your free t-shirt with pride...
Welcome to the club - here’s your free t-shirt as well...
MrNeutral
2021 Ford Ranger XLT 4x4
I just did this. Followed your instructions and it took me about 45 min. Had a dremmel multitool so that helps with the cuts. You sir are a genius. I hated the air dam and when I took it off, I hated the "gap" just as much. Thank you for posting this.
Thanks Derek. Dremel to the rescue. I’m so glad it worked out. Here’s your free t-shirt.
evoaire
VA
9.5” Redwing
My ranger is ordered. And I’m a big fan. I’ve read all 35 post in this here thread. And I was wondering, could I have a tee?
After careful consideration, I’ve decided against it. These coveted tees are not given out lightly and I’m certainly happy to reward those who complete the mod - it just wouldn’t be fair to those who have. It’s not like AZScorpion hands out his damper club tees without pics.
@DukeCanBuildit Thanks for this great free mod! Performed it today and happy with how much it cleaned up my front end!!!!
Hey Anthony,
I’m glad you’re pleased with the result. As a reward, here’s your free t-shirt wear it proudly. I hope I got your size right. ?
Nice SuperCab by the way. There’s another Scab owner on here from the San Diego area who meets up with some of the ranger5g members to go wheeling in the desert. Check out @dondonbabyraptor (Brandon) - I think he’s been out with @XL_Ranger_Danger and maybe @BladeRanger.
Rockhound
Albert
SoCal
2020 Ford Ranger 4x4 XLT
Cabinet Installer
Brilliant engineering!
This is why you don't throw parts away that you remove for modifications.
First mod I made was to pull the dam. I ran the skid pate for a while but hated the gap and couldn't come up with a fix. So I pulled the skid plate. That looked better but exposed the crossmember to danger on the trail.
I ran across this post yesterday and did the mod today.
It eliminates the air dam, retains the skid plate and blends the gap from bumper to top of skid plate beautifully, and costs nothing!
Thanks for working this out and posting with great instructions.
Thanks Albert,
I‘m glad so many people are getting a lot out of this free and easy mod. Enjoy your free t-shirt. Like the Ford Model T, you can have it in any colour you want, as long as it is black. ?
CaptainVonAwesome
Captain
Modesto
2021 Ranger
I removed the air dam on my XLT and, like many others who have done the same, I didn't like the gap between the bumper and the existing skid plate. It just looked odd and I could see it scooping up mud, snow, etc.. Solution: buy a factory skid plate or modify your old air dam to fill the gap.
You'll need a drill or 1/4" impact driver (contractor kind, not mechanic kind), 1/4" hex to 3/8" drive adapter), 10mm socket (long), 15mm socket (long), razor knife, tire crayon, 3/16" drill bit. (Don't freak out - you're not drilling into your Ranger).
If your air dam is off, you'll need to partially mount it to make the mod. Using the 10mm socket, mount the middle (short one) of the three outer mounting tabs in its original mounting spot, while leaving the other two long tabs on the outside of the bumper ( will be easily understood when you're doing it. Repeat for other side. This makes it way easier to re-install the middle tabs and to mark up your air dam for cutting.
Remove the three bumper skin bolt from the bottom of the bumper, push the bumper skin away and install the three middle air dam bolts in their original mounting position using the 10mm socket. Do not re-attach the bumper skin at this point.
Remove the two forward skid plate bolts using the 15mm socket. The skid plate should sag - if not, loosen the next set of bolts toward the rear of the skid plate but do not remove them. Tuck the air dam above the skid plate and secure one side with a 15mm bolt to hold in place. Wrestle the dam in place and secure the other side. You don't need to fully tighten the bolts but they need to be snug enough to hold things in place while you figure out where you need to cut. Ignore how poorly the dam fits at the outer tab - we'll be fixing that by cutting off the tab and drilling a new mounting slot in the air dam.
Use the tire crayon to mark where you need to cut - the outside edge of the skid plate should be your guide.
Remove the air dam to make the final markups and cut the air dam. Starting from the outside edge of the middle tab, draw a line straight down to the bend, follow along the bend for a few inches, then arch toward the line you traced along the outer edge of the skid plate. Mark a 1" line about 1-1/2" to the inside of where the skid plate will end - this will be a relief cut to allow the air dam to suck up against the skid plate mounting point See photo. Repeat for the other side.
Make sure your razor knife has a new blade. Carefully score where you need to make your cuts. Score again. Score again until you cut through - slow and steady wins the race here! The large outer piece should be completely cut away at this point. Cut off the two outer tabs, flush to the air dam. Make your relief cut. Repeat for the other side.
Using the 3/16" drill bit, make a slot on the outer end of the air dam by drilling two holes very close together and about 3/16" from the end of the air dam. Use the drill to "router" the slot - it doesn't have to be perfect, only functional. Repeat for the other side.
Now, re-install the dam, starting at the outside, now the other side, finishing with the three bolts under the bumper skin. The fit at the outside edges should be much better. Do not fasten bumper skin yet.
Snug the air dam under the skid plate and loosely fasten one side of the skid plate, then the other. Now tighten both skid plate bolts - you should be able see how the relief cuts were helpful. Tighten the rear bolts if you loosened them.
If everything looks good, install the three bumper skin bolts using the 10mm socket.
Beez
Wayne
Hawaii
'19 Lariat, DIY BOV, 2.5 Leveler, MBRP 3" Exhaust
Just another incredibly super average dude
Duke... Seriously... Your vision and craftsmanship are to be highly commended. I love this DIY mod and am looking forward to doing this with my Ranger. Sure glad I didn't chuck my air dam in the recycling bin when I removed it to paint my skid plate. Thanks for posting!
Thanks Wayne.
The best mods are free and this one is fun to do, even for incredibly super average dudes - let me know how it goes.
