DMac
I went with these with 275/70/17 BFG KO2’s. The rim is 17x8.5 w/34mm offset. I will post a pic once they are on.Noooo, not 20” rims, I’m getting 17x8.5 with 34mm offset. I chose the XD Holeshot rims
Here's a quick Photochop of Magnetic crew with black Shok...about I'll be driving in give or take 42 daysAnyone have the Fuel Shok on yet? I see Panda is carrying them.
Nice! Please post pics when you can. What tires?Here's a quick Photochop of Magnetic crew with black Shok...about I'll be driving in give or take 42 days
Decided that Magnetic and Anthracite will play really well together
Just placed my order with Mr Panda for these
Not the one in the google pic...this one...Nice! Please post pics when you can. What tires?
Here ya are sir!!!!!
17x9 Fuel Vandals +1 offsetDo you mind if I ask what the specs of those rims and tires?
Thanks! Any rubbing issues or did you have to cut/chop anything? Also, did you do a leveling kit or a lift kit?17x9 Fuel Vandals +1 offset
265/70/17 BFG Allterranins
Leveling kit!!!!! I do have a little rubbing when I turn 3/4 way in both directions on the outer crash bar. It doesn't bug me too much but I do plan to trim the outer crash bar when I get a day off from work.Thanks! Any rubbing issues or did you have to cut/chop anything? Also, did you do a leveling kit or a lift kit?
Here’s how it ended upI went with these with 275/70/17 BFG KO2’s. The rim is 17x8.5 w/34mm offset. I will post a pic once they are on.
YES! Falcons right? That's about what mine will look like with Fuel Shok wheelsJust swapped on the 17" RR2-V with 285/70R17. Level'ed temporarily on Rough Country to get this set up running. It rubs the body mount making hard turns and turning in reverse. However, it's still driveable.
Used this promo code for $50 Off @ www.RelationsRaceWheels.com
Code: DSRH
