110V Outlet Not Powering Device
Brett Fields
Brett
Brooklyn
Paramedic
You could try something like
Bestek 300 watt
and pull 10 amps out of the 12 volt recepticle...
Or just go totally nuts.
I know... I'm not right in the head.
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
Probably be best to contact the company that manufacturers them and see if they have any idea why it wont run on a modified sine wave inverter. There must be more then a fan in it that's causing the issue.
Perhaps the start-up current is too high. Just a wild-ass guess.
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
I have a 2020 Ranger. Sometimes I plug a wireless phone charger to the AC outlet and it works fine. I rented a 2022 Ranger and tried to use the AC outlet with the wireless phone charger; the phone would start to charge, then stop. Basically it wouldn't work. So they have probably changed the inverter in the newer vehicles. It probably will not work when used with some AC to DC transformers.
jblc
JB
USA
2021 XLT FX2 supercab
+1 the other idea that this onboard inverter is modified sin wave, and might not work with certain electronics. especially inductive like motors, but could be other sensitive electronics as well even if they have a low power rating.
Dereku
Chicagoland Area
Bestek 300 watt
Holy hell. Who needs a clock tower and a lightning rod. Be careful at speeds around 88 MPH
I would just hang one of these from the rear view mirror and call it a day.
Agreed.
What is purpose of an air purifier in a vehicle?
Zetterbeard
Zetterbeard
Zach
2020 FORD RANGER XLT 4X4
Agreed.
I don't want to cover up smells with other smells. Ideally there is no smell in the vehicle. I use a couple charcoal filters as well. The purpose was intended to be as simple as you probably already thought...
Dereku
Chicagoland Area
So it is to purify the air? No way! ??
I mean, the windows work well for me. But whatever floats your boat.
Zetterbeard
Zetterbeard
Zach
Thanks for the info, definitely not knowledgeable enough to have guessed that!
Eskram
FL
2022 F-150 Lariat 502a Powerboost Hybrid
I thought the interior circuit was good for 20a?
