110V outlet is flashing
jubreunig
Juergen
Tuscaloosa AL
Hey guys,
I used the 110V outlet sometimes to inflate my tube and it works as it should. But since the last weekend, the air pump start running and breaks immediately, and then is the LED from the outlet flashing and nothing happens until I switch the ignition off/on and same game like before.
What I have read in the manual, the outlet is for 100w maximum, my air pump has 200w.
But why it works in the past? And what are 100w? That's nothing. My Tacoma has supported 400w.
For what does you use this outlet? (except the night light mod)
VAMike
2019 Ranger Lariat SuperCab
sounds like you're over current and the circuit breaker is tripping as it's designed to. the manual covers this, and also says not to use the outlet for motor loads. it's designed for consumer electronics (laptops, chargers, etc.) not heavy loads.
jubreunig
jubreunig
Juergen
Tuscaloosa AL
Each laptop charger takes more than 100. This thing is nothing worth
VAMike
I don't know where you got 100 from, the manual says 150W for the AC socket. I don't have any laptops that draw more than that, I guess if you do you could get a more efficient laptop? ?‍♂
jubreunig
jubreunig
Juergen
Tuscaloosa AL
You´r right with 150, but still too less for my use
