Water leaking onto spark plugs
NotBudule
XLT
Well , was washing my truck just now so I took end off hose and just let it flow down windshield , sure enough, a pretty good drip every 6 or 7 seconds , still seams like it would evaporate, but I guess not , the main drip is coming from the push rivet in the center , where the 2 cowl pieces meet , the true fix is in that cowl methinks , the TSB is just an umbrella ?...a piece of wire loom would probably deflect it off the plugs though...
if one parks outside , and a monsoon comes , a lot of water would leak on a cold engine , that's a problem...
I stuck my blower nozzle in there , 3 and 4 were wet , I don't think it can get up to 2 or 1
Mods might want to move this in TSB with the cover ? I think it's all related , Im sure it is now ...
NotBudule
NotBudule
XLT
seems to be lots of water ? gathered around the wiper arm shaft,
SHOULD be running backwards and down and out by the fender in the corner ... I am going to build a silicone dam and see if it will divert it away ...
black duct tape holding those together ...
NotBudule
NotBudule
XLT
Hard to get in there without taking off the wiper arms ,which I didn't want to do anyway , built that area up with silicone a bit to try and divert , also , that piece and the metal tabs that the rivets go in were all pointing down ?, I bent them back up a bit, gona button it back up and test it again in a few days ...
Bob902
St. Louis
RETIRED!!!!
It can't be a coincidence that all the water seems to be coming from where these 2 pieces meet , it's kinda crappy and they had tape on it , if I had black sealant , I'd seal it...
Does kind of seem like a funnel for water.
NotBudule
NotBudule
XLT
Well it's right over the plugs , if I have to ill mix up some glow water and black light find it, my guess is , if your driving the truck and engine is hot , any rain that leaks on it just evaporates , park outside though, lots of rain and no drivey , water build up , I'm in a garage so I doubt it would even effect me , but don't want a constant drip on my 3 and 4 coils in the rain ...
Bob902
St. Louis
RETIRED!!!!
I agree driving shouldn't be issue. Just parked outside in a heavy rain. That design lends itself to put water over that grommet which is right over the coil. If your idea works, I might just try to put some black rtv where the pieces meet up.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Damn and add to that not driving as much the last 2 yrs!
And rather than find where the water was coming in Ford but an umbrella on it ?
NotBudule
NotBudule
XLT
I'm predicting that when people start getting enough miles to change plugs , some are going to have a rough time with 3 and 4 ... especially those who park outside in places that rain ? , or people that wash theirs all the time (ME)...
William Oz
Bill
Redford, MI
2019 Ford Escape
Autoworker
I read somewhere that there was a TSB on this and the solution was to install the deleted engine cover.
micl9
Apex, NC
Yeah I park outside. I probably need to at least pull the ign modules and take a peek.
Maybe add a squirt of oil at the base of the plugs.
LOL I will wait till my EGR valve comes in - also a water issue!
Really good sleuthing on this Robert. When I saw the TSB I was wondering how the hell does water get on the top of the engine. Figured it was road splash - but that would be a hot engine. It didn't make sense. Now it does.
NotBudule
NotBudule
XLT
c
I'm thinking a quick fix would be a short piece of split wire loom or split foam pipe insulation , cover that edge and right over the push rivets , just moving that drip 6 inches left or right would keep it off the plugs ...
micl9
Apex, NC
c
I do have the Umbrella cover now, but 1st 2 yrs was without it.
The more I think about it the more I cant believe Ford didn't catch this. They do extensive rain tests. Well I guess they mainly worry about cabin ingress not engine compartment.
Although I hear they missed that on the soft top Broncos!
